car wont start with key, but with r/s
playtilithrtz
Member - Posts: 22
Posted: January 10, 2006 at 8:57 PM / IP Logged
Car:  04 Hyundai Tiburon GT
Alarm: Viper 791xv w/ remote start
Symptom: Car will only turn on with remote start, but not with the key.
Explination: I installed this alarm and i followed the guide lines correctly (i suppose). I have installed this alarm on my car and someone elses car with no problems ( same type of car and same remote start/alarm). I did the installation on a manual and i bypassed the clutch with no problems. the car turns on fine when i hit the "8" key 2x and it starts right up. But when you go insert the key it wont crank. the dash lights and the headlights turn on but no starter click or anything. I think i hear the fuel pump turn on but am not completly sure. I checked the only fuses that could be for ignition and they are okay. The ignition harness is plugged in. ( the car turn on before after the install, and after i bypassed the clutch, but i know i did a few other connection and then left it alone till about 6 hours later.)
Now the only thing that boggles my mind is this. the one ribbon cable that goes to the brain to the remote start relay box that cable was cut. (alarm was preinstalled by installers) the one yellow wire was connected to the ACC line for some reason off the ignition harness. why did they do this? so what ever i cut the wires and soldered and reattched all the cable so that i can connect both end to each unit. but car turned on, but i dont know if it turned on with the key. i dont remember trying.
can anyone give me some information on what may be the problem? i tried to connect that yellow wire back to its original location, but that did nothing.
thank you inadvance.
matt.
stang351w
Silver - Posts: 350
Posted: January 10, 2006 at 9:01 PM / IP Logged
sounds kinda like the starter kill relay isn't wired properly. that's where i'd start.
Tri County KustomZ
certified installer
playtilithrtz
Member - Posts: 22
Posted: January 10, 2006 at 9:54 PM / IP Logged
okay now this sounds dumb, but where is that? is it that module with those thick wires that connect to the ignition harness?
silvercivicsir
Copper - Posts: 416
Posted: January 11, 2006 at 12:30 AM / IP Logged
flip around the heavy guage green wire and purple.. sounds like you have them backwards.
dstang24
Copper - Posts: 98
Posted: January 11, 2006 at 3:27 AM / IP Logged
agreed...
playtilithrtz
Member - Posts: 22
Posted: January 11, 2006 at 2:48 PM / IP Logged
okay i will try that and ill see what happens.
Hornshockey
Silver - Posts: 520
Posted: January 11, 2006 at 6:04 PM / IP Logged
that's not gonna be your problem if it starts properly with the RS.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
cntrylvr79
Silver - Posts: 582
Posted: January 11, 2006 at 6:42 PM / IP Logged
Try disconnecting the ribbon harness from the brain of the alarm.  If it starts now check the orange wire from the 12pin harness make sure it's not connected to anything or shorting out.
Cause I'm So white and nerdy...
First Class Certi-fried installer
playtilithrtz
Member - Posts: 22
Posted: January 11, 2006 at 7:31 PM / IP Logged
okay.... i will have to take a look at that.... i thought that the previos post with the purple and green wire didnt make sence, realized that afterwards.
ryguy
Member - Posts: 44
Posted: January 11, 2006 at 7:43 PM / IP Logged
un arm the car ??
MECP installer,technician
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
