motorjoy rs/alarm
ps2sidewinder
Posted: February 01, 2006 at 3:24 PM / IP Logged
Hi i tryed searching the forum still have trouble on hooking up my parking lights, Door locks on 1996 1500 dodge ram full size pickup heres the remote starter i have
motorjoy rs/alarm -- posted image.
i hook up the brown wire from the rs to the truck wire BLACK / YELLOW (+) wire @ yellow plug drivers kick panel and the lights wont flash is there somthing i need to get it going last thing power door locks this is the way i did it wires from rs unlock signal WHITE/ black to pink/violet blue plug @drivers kick panel, lock signal white from rs to ORANGE / violet blue plug @drivers kick panel, rs yellow/black +12 volt, yellow +12 volt to trucks +12 volt then i tried to lock and unlock pops the fuses all the time any ideas would be great everthing else on the rs is done just need the lights and door locks thanks.
Powermyster
Silver - Posts: 962
Posted: February 01, 2006 at 5:35 PM / IP Logged
use the two browns for you one parking light
Why oh Why didn't i take the blue pill
Darren Power
ps2sidewinder
Posted: February 01, 2006 at 5:45 PM / IP Logged
motorjoy rs/alarm -- posted image. Thanks powermyster that worked my lights flash when i hit the alarm but when i remote start my truck the parking lights don't come on, any idea on the door locks Thanks for ur help.
Powermyster
Silver - Posts: 962
Posted: February 01, 2006 at 6:03 PM / IP Logged
we don't have these vehicle's here so i have never done one
Door Lock     ORANGE / Purple      10 Pin Connector Driver's Kick or behind Glove Compartment
Door Unlock     Pink/Purple      Reverse Polarity
your alarm appears to have locking relays so you will not have to use extra ones. check your cental locking page to see what the other wires are it doesn's say on that page
Darren Power
ps2sidewinder
Posted: February 01, 2006 at 6:58 PM / IP Logged
Ok this is what i did to try it out it worked but it only unlocks & locks my drivers door doesn't do anything to passenger door i went straight to the switch in my door panel
any ideas how to get both doors to lock and unlock
ps2sidewinder
Posted: February 01, 2006 at 7:05 PM / IP Logged
and i cut the 2 wires going to the switch to the door lock because when it was connected it keep on poppin the fuses
ps2sidewinder
Posted: February 01, 2006 at 10:04 PM / IP Logged
anybody any ideas
stockgp
Member - Posts: 13
Posted: February 14, 2006 at 10:07 AM / IP Logged
i might be able to help. i'm the one who posted the pic you are using of the diagram.
first, do you have the box and instructions and everything for this system?
Platinum - Posts: 12,488
Posted: February 14, 2006 at 10:21 AM / IP Logged
5 wire both the lock and unlock. I had this happen to a Dakota as well and I ended up 5 wiring both wires.
mo12v
Posted: February 14, 2006 at 10:48 AM / IP Logged
Not familiar with the System you have but, Using the Wire Diagram you posted the 2nd time:
@ driver Kick Panel:
You should be able to Unsnap the Plug & Boot on the outside between the Door & Kick Panel.
 ( Push in on 4 corners of Boot & Plug.  You don't have to take rubber boot off )
 Then pull wires thru to outside to connect a little easier.
( might require a hook tool to Unsnap the 4 corners of the plug.  I usually unsnap 3 and it comes out.
Cut ORANGE / Violet LOCK  & PINK / Violet UNLOCK Wire in Half.
One Half of Lock & Unlock wire goes to Door SWITCH
Other Half of Lock & Unlock wire goes to ACTUATORS
Test wires with METER
LOCK:
Connect SWITCH side of cut LOCK wire to ORANGE wire on 6 PIN Plug.
Connect ACTUATOR side of cut LOCK wire to WHITE wire on 6 PIN Plug.
UNLOCK:
Connect SWITCH side of cut UNLOCK wire to ORANGE / Black wire on 6 PIN Plug.
Connect ACTUATOR side of cut UNLOCK wire to WHITE / Black wire on 6 PIN Plug.
Connect YELLOW / Black & YELLOW wire on 6 PIN Plug to Constant 12 volt ( + )
MO
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
