2001 monte carlo aftermarket security
xenonmatrix
Member - Posts: 43
Posted: March 25, 2006 at 10:52 PM / IP Logged
i ahve a 2001 monte carlo 3.4 v6 no onstar that i am wanting to put a aftermarket security system in along with remote start, i was hoping if it  was possible to get a wiring guide along with a idea of the location of the wiring for the 2001 monte carlo. thank you
KarTuneMan
Platinum - Posts: 7,056
xenonmatrix
Member - Posts: 43
Posted: March 26, 2006 at 5:54 PM / IP Logged
The drivers door trigger wire is blue. Blue/white will catch the passenger door. Use both wires and diode isolate each.
it what meaning do they have for this, like there is supposed to be a diode in each wire with teh chathode facing in what direction and thank you for the wiring diagram
xenonmatrix
Member - Posts: 43
Posted: March 26, 2006 at 5:59 PM / IP Logged
is it also possible to get this information if you dont mind at all thank you
DirectFax document 1076 for wiring information.
See DirectFax document 1600 for wiring information.
Lock and unlock use the same wire. Lock requires a
negative trigger with a 470 ohm resistor in-line.
Unlock is negative trigger. Must use relays.
Platinum - Posts: 12,488
Posted: March 27, 2006 at 10:43 AM / IP Logged
For D.FAX 1600 all it says is to diode or relay isolate the parking light wire otherwise you will get a check engine error after remote starting. Have the diode inline of the (-) parking light output with the cathode band towards the BCM.
xenonmatrix
Member - Posts: 43
Posted: March 27, 2006 at 5:12 PM / IP Logged
awesome thank you! any information on document  1076 for like the trunk
CHEVROLET, MONTE CARLO, 2001, Trunk/Hatch Pin
The BCM is located above the brake pedal. It is a plastic box with three plugs that face the firewall.
Have to also diode isolate from the BCM to prevent false alarms. Refer to DirectFax document 1076 for wiring information.
thank you!
xenonmatrix
Member - Posts: 43
Posted: March 27, 2006 at 6:25 PM / IP Logged
CHEVROLET, MONTE CARLO, 2001, Factory Alarm Disarm
the color is light green do i need to cut that wire? or no?
Posted: March 27, 2006 at 10:21 PM / IP Logged
Just use the Negative Door Trigger Diode Isolation diagram for the trunk as well. The OEM disarm wire you have to tap into with the OEM disarm output of the alarm/remote starter.
xenonmatrix
Member - Posts: 43
Posted: March 27, 2006 at 10:30 PM / IP Logged
i just want to thank you for helping me out with this! this some really great information! thank you!
xenonmatrix
Member - Posts: 43
Posted: March 27, 2006 at 11:05 PM / IP Logged
Do you have any idea where this wire would be located? i notice there the same color but possible different locations any ideas?  thank you
Brake Wire white   +  brake switch
Tachometer white    ignition coil
Page of 7
