Trunk Release hook up in mustang
gtstang03
Member - Posts: 6
Posted: June 04, 2006 at 7:31 PM / IP Logged
Hello
I am in the need of help, I have a 2003 mustang gt with a viper 350v alarm. I realize i need a relay to hook up the trunk pop. I found the trunk pop wire (purple w/ yellow) to tie into. I do believe i found the wire that comes from the brain RED / white wire. Although i am not sure what type of relay i should use? Also i was using a multimeter on the red w/white wire and i could not get anything to read when testing it.
Any help or info will be great.
david
mo12v
Posted: June 04, 2006 at 9:31 PM / IP Logged
It should read approx 250ma on your Meter
SPDT ( Single Pole Double Throw ) Relay:
PIN 87 =Constant 12 volt ( + )
PIN 87a = XX
PIN 30 = TRUNK Wire
PIN 85 = Negative Trunk Output fromUnit
PIN 86 = Constant 12 volt ( + )
MO
gtstang03
Member - Posts: 6
Posted: June 04, 2006 at 10:20 PM / IP Logged
PIN 87a = XX
PIN 30 = TRUNK Wire
Great thanks!
gtstang03
Member - Posts: 6
Posted: June 05, 2006 at 9:25 AM / IP Logged
Not sure if this is a stupid question but how do i tes the the wire is producing 250 ma on my Multimeter?
mo12v
Posted: June 05, 2006 at 10:16 AM / IP Logged
Depending on your Meter:
Be sure you Meter is on MA or OHM
One side of Meter to GROUND
Other side of Meter to Trunk Output Wire.
Press Trunk Button on Remote
If your Viper is Functioning you should get a reading
MO
gtstang03
Member - Posts: 6
Posted: June 05, 2006 at 10:35 AM / IP Logged
I will have to check it again. I beleive that was how i was testing it as my meter does have MA and ohm. I was not getting anything. I don't have a wiring diagram off the viper 350 but ready some other diagrams off other viper alarms the trunk or aux output was the red and white wire which I found not hooked up to anything. Could it be another wire?
Thanks again.
mo12v
Posted: June 05, 2006 at 11:16 AM / IP Logged
Here is PDF for 350HV:
http://www.directeddealers.com/manuals/ig/viper/N426V_07-05.pdf
MO
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
