Valet Remote Start, Wire diagram?
What wires, specifically, are you unsure about?
DEI Valet 561t 2000 Ford Explorer Question
5 port
BLACK/ White neutral safety shutdown to RED / Light Blue Where is this located?
Violet/White tachometer input to Tan / YELLOW @ coil
Brown (+) break shutdown to Light Green @ break switch on break peddle bracket
Grey hood pin shutdown to Tan/Light Green (-) @ driver's kick pannel
Blue/White 2nd status output/defogger to ? Where does this go to?
9 port
WHITE/ Red (+) activation input to ? Where does this go to?
RED / White (-) 200mA channel 2 output to ? Where does this go to?
Black (-) ground input to ground
White (+/-) parking light output to Brown or WHITE/ Black @ headlight switch or drivers kick pannel
Grey/Black (-) wait to start input to Do not need.
WHITE/ Blue (-) activation input to ? Where does this go to? Is this the same as the WHITE/ Red wire above?
Yellow (-) ignition output to Light GREEN/ Purple @ ignition switch
GREEN / WHITE (-) factory alarm rearm to ? Where does this go to?
GREEN/ Black (-) factory alarm disarm to Dark GREEN/ Purple @ drivers kick panel
4 port
Pink (-) 200mA third ignition turn on to BLACK/ Green @ ignition switch
Purple (-) 200mA second starter turn on to ? Where does this go to?
Orange (-) 200mA accessory turn on to Grey / YELLOW @ ignition switch
Blue (-) 200mA status output to ? Where does this go to?
6 port
Red 12V hign current input to Yellow @ ignition switch
Pink ignition output to Light GREEN/ Purple @ ignition switch Is this the same as the yellow wire above?
Violet starter output to RED / Light Blue @ ignition switch
Orange accessory 1 output to ?
Red 12V hign current input to ? Where does this go to?
Pink/White ignition 2 output to Grey / YELLOW @ ignition switch
Do these look correct?
Thanks for the data. I have a few more questions.
Red 12V hign current input to ? Where does this go to? red is 12v- connect to the yellow of the Ford. Why are there two red high current input wires? Do they both go to the same yellow wire?
Just to confirm, I should not use any of the wires comming out of the 4 port connector. What are these usually used for?
Thanks again,
5 port
BLACK/ White neutral safety shutdown to RED / Light Blue that’s usually to the switch that is included. So you can turn off the R/S function when you take the car to the shop so it doesn’t accordantly r/s. Or you can simply ground it.
Grey hood pin shutdown to Tan/Light Green (-) @ driver's kick panel
Blue/White 2nd status output/defogger to ? Where does this go to? To your bypass
WHITE/ Red (+) activation input to ? Where does this go to? Dont use
RED / White (-) 200mA channel 2 output to ? Where does this go to? No need (usually trunk pop)
White (+/-) parking light output to Brown or WHITE/ Black @ headlight switch or drivers kick panel
WHITE/ Blue (-) activation input to ? Where does this go to? Is this the same as the WHITE/ Red wire above? Dont use
4 port
Pink (-) 200mA third ignition turn on to BLACK/ Green @ ignition switch Your ford exploreer does not need port 4. DO NOT USE THIS.
Purple (-) 200mA second starter turn on to ? Where does this go to? Your ford exploreer does not need port 4. DO NOT USE THIS.
Orange (-) 200mA accessory turn on to Grey / YELLOW @ ignition switch Your ford exploreer does not need port 4. DO NOT USE THIS.
Blue (-) 200mA status output to ? Where does this go to? Your ford exploreer does not need port 4. DO NOT USE THIS.
6 port
Red 12V hign current input to ? Where does this go to? red is 12v- connect to the yellow of the ford.
captainzab,
Thanks for all the great info. One more question. You lost me on the Yellow (-) ignition output. DO I have to connect the Pink/White ignition 2 output and the Pink ignition output in the 6 port byt not the Yellow (-) ignition output in the 9 port? Since I have a factory alarm system and am just using the 561t as an add on would this change anything?
Thanks again,
JM
Here is what I have so far. What wire does the BLACK/ White neutral safety shutdown connect to? I have RED / Light Blue, whick is the same as the starter output?
5 port
WHITE/ Red (+) activation input to Not used
9 port
RED / White (-) 200mA channel 2 output to Not used (usually trunk pop)
Black (-) ground input to Ground
Grey/Black (-) wait to start input to Not used
WHITE/ Blue (-) activation input to Not used
Yellow (-) ignition output to Not used Tape it real good. This is an output to a security system if you were using the 561T as a remote start add on.
GREEN / WHITE (-) factory alarm rearm to Not used
4 port
Pink (-) 200mA third ignition turn on to BLACK/ Green @ ignition switch Your ford explorer does not need port 4. DO NOT USE THIS.
Purple (-) 200mA second starter turn on to ? Where does this go to? Your ford explorer does not need port 4. DO NOT USE THIS.
Orange (-) 200mA accessory turn on to Grey / YELLOW @ ignition switch Your ford explorer does not need port 4. DO NOT USE THIS.
Blue (-) 200mA status output to ? Where does this go to? Your ford explorer does not need port 4. DO NOT USE THIS.
6 port
Red 12V high current input to Yellow @ ignition switch
Pink ignition output to Light GREEN/ Purple @ ignition switch (1 of 2 wires, use either wire)
Orange accessory 1 output to GRAY / YELLOW. There are 2 in the ford. Pick either one, but not both.
Pink/White ignition 2 output to Grey / YELLOW @ ignition switch might be BLACK/ LIGHT GREEN
DEI 556U Immobilizer Interface 2000 Ford Explorer
6 pin harness
Red (+) 12 Volt Input to Yellow @ ignition switch
Blue (-) Status Input to Blue/White 2nd status output/defogger on the 561t
Pink (+) Ignition Input to Not Used
Black (-) Chassis Ground Input to Ground
Violet (+) Keysense Input to Not Used
Green (-) Keysense Input to Not Used
3 pin harness
Black Antenna wire to Around Vehicle ignition switch
BLACK/ Red Antenna wire to Around Vehicle ignition switch. Attached to wire above
BLACK/ White to Not Used
Sorry. Lets try this again. Here is what I have. The RED / Light Blue wire is throwing me. Ihave it for my starter and nutral safty switch from th toggle.
5 port
9 port
WHITE/ Blue (-) activation input to Pink / YELLOW (-) Drivers Kick Panel (Door Lock)
4 port
6 port
6 pin harness
3 pin harness
Saturday, February 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
