2006 Avalon, remote start?
mobilecustoms
Silver - Posts: 397
Posted: October 20, 2006 at 3:15 PM / IP Logged
Can a remote start be added to a 2006 toyota avalon limited with the smart key- no hybrid. gas only car? How do i bypass the smart key? Does anybody have a wiring diagram?
thanks
gcorrea
Silver - Posts: 436
Posted: October 20, 2006 at 9:36 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / AVALON / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      black (30A), orange (7.5A)       +       ignition harness
Starter      blue       +       ignition harness
Second Starter      red       +       ignition harness
Ignition      yellow       +       ignition harness
Second Ignition      green       +       ignition harness
Third Ignition      N/A
Accessory      gray       +       ignition harness
Second Accessory      N/A
Keysense      black       -       ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock      black to brown       -       driver kick, 20 pin plug, pin 9
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock      gray to purple (double pulse)       -       driver kick, 20 pin plug, pin 19
Can also use the passenger door key cylinder wire, which only requires a single pulse. It is gray to yellow (-) in the passenger kick, 20 pin plug, pin 8.
Lock Motor      red to white       5wi      driver kick, 20 pin plug, pin 1
Unlock Motor      white to gray       5wi      driver kick, 20 pin plug, pin 20
Parking Lights+      do not use, relay rests at gnd
Parking Lights-      blue       -       headlight switch
Hazards      yellow       -       switch or turn signal flasher, pin 8
Notes: The turn signal flasher is under the driver side dash, against the firewall.
Turn Signal(L)      black       +       turn signal flasher, pin 3
Turn Signal(R)      pink       +       turn signal flasher, pin 2
Reverse Light      pink to black       +       driver kick, 17 pin plug, pin 2
Door Trigger      see notes       -       each kick, harness to rear
Notes: The LF door is pink to blue, RF door is purple to blue, LR door is black, and RR door is gray. Use all four wires and diode isolate each.
Dome Supervision      brown       -       R side of fusebox, 12 pin plg, pin 5
Trunk/Hatch Pin      white to purple       -       driver kick, blu 20 pin plug, pin 17
Hood Pin      blue       -       pin switch under hood
Trunk/Hatch Release      blue       -       trunk release switch on dash
Notes: The trunk release motor wire is black (5wi) in the driver kick, blue 20 pin plug, pin 11.
The fuel lid release is gray to green (+) at the release switch on the dash or in the driver kick, blue 20 pin plug, pin 15.
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock      use key sense wire
Tachometer      white       ac       ECM, second plug from top, pin 1
Notes: The ECM (Engine Control Module) is behind the glove box.
Can also go to any fuel injector and use the wire that is NOT brown.
Wait to start      N/A
Brake Wire      white       +       brake pedal switch
Parking Brake      lt. green       -       parking brake switch
Horn Trigger      gray       -       horn switch in column cover
Memory Seat 1      green       -       memory seat switch in door
Memory Seat 2      purple       -       memory seat switch in door
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
gcorrea
Platinum - Posts: 12,488
Posted: October 21, 2006 at 9:58 AM / IP Logged
I have not worked on this vehicle yet but this is what I've heard, take apart the key fob and put a relay on the battery and tie in the fob to the unversal bypass module and it will start.
chadwa2003
Copper - Posts: 353
Posted: October 21, 2006 at 10:50 AM / IP Logged
Hello Jeff
Can you elaborate on this set-up you have reffered to? What do you mean by "take apart the key fob and put a relay on the battery and tie in the fob to the unversal bypass module and it will start"?
Chris Luongo
Platinum - Posts: 3,746
Posted: October 21, 2006 at 7:05 PM / IP Logged
Have you used the search feature? All of the information you seek should be able to be found here, as well as at the Security forum at carsound.com/forum
