2006 Dodge Ram Diesel, Remote Start
jacked93
Member - Posts: 17
Posted: October 30, 2006 at 1:45 PM / IP Logged
I bought this remote start system off of ebay, http:///.com/ebaymotors/GV9-2-Way-LCD-Car-Alarm-Remote-Start-Programmable_W0QQcmdZViewItemQQcategoryZ33721QQihZ006QQitemZ160041865248QQtcZphoto I really wanted one, but couldn't afford the $500+ price tag that some shops here wanted to install a system.  I am pretty handy so I figured I would give it a shot installing it myself.  After finding this site it looks like it may be harder than I thought, didn't think there would be some many relays, 5 from what I can tell, and resistors.  I think I am a little overwhelmed.   My questions.
1) Is this system even any good?
2) Can a novice install somthing like this?
Thanks in advance
green6767
Copper - Posts: 209
Posted: October 30, 2006 at 2:05 PM / IP Logged
If you've never installed a remote starter before, this may be a bit of a task for ya. Those trucks aren't necessarily hard to do given the proper bypass module and methods of installing, but then again, its not a cake walk. If you aren't going to use a bypass kit, it may be a bit of a challenge for you, not sure how much you know about remote starters. As far as the system goes, I'm not able to access your links, but I took the auction number out of the link and looked it up that way. It "looks" decent, never heard of the brand, but looks can be very deceiving. Maybe somebody can offer some input on the brand, as I have not much experience with that particular brand.
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
jacked93
Member - Posts: 17
Posted: October 30, 2006 at 2:15 PM / IP Logged
For some reason I can't get them to work right, they work when you preview the post, but not once it is posted, it removes the first part of the link.
I bought a bypass module already, I still think I can do it, the relay and resistor thing is what worried me at first, but I guess its not really that big of a deal, just have to head to radio shack for some relays and resistors.  Looks like 6 of each.
The ebay item # is   160041865183
Remote Start
Twelvoltz
Platinum - Posts: 2,384
Posted: October 30, 2006 at 2:22 PM / IP Logged
FYI, eBay links are blocked in this forum.
The item you are inquiring about is not from a brand I am familiar with. I would recommend sticking with 'known' brands like DEI, Compustar, or any of the others that are recommended by other users of this site.
As far as the installation goes, I would recommend picking up one of these.
This device will do door locks, arm/disarm, eliminate the need to purchase another key and second starter/accessory outputs.
Like any other job if you have the right tools and knowledge the job is not difficult. This site's users will provide you with all the knowledge you will need to do the job correctly. There are even threads on how to properly solder a connection. Do as much research as you possibly can, then determine for yourself is this is a job you are willing to try and tackle.
xtremej
Gold - Posts: 1,440
Posted: October 30, 2006 at 2:26 PM / IP Logged
Ebay links are blocked by the filter on the 12 volt forum. The bypass you'll want to buy is from bypasskits.com part #CHDL7-pk2, it will handle the 2nd start/accesory  and doorlocks it must be programed by 2 programmed keys to work as the igntion bypass. This is not an easy truck for a novice. If you put it into theft mode it will cost you a tow to the dealership. Also if the dealership has the the bcm locked so you can't program keys you won't be able to program that bypass.
jacked93
Member - Posts: 17
Posted: October 30, 2006 at 2:39 PM / IP Logged
This is the bypass kit I bought.
Ebay item #  150043123542
xtremej
Gold - Posts: 1,440
Posted: October 30, 2006 at 3:52 PM / IP Logged
I tried your ebay item # I didn't get anything? post the brand and model #.
green6767
Copper - Posts: 209
Posted: October 30, 2006 at 4:31 PM / IP Logged
The module from bypasskit.com will help ALOT! You wont need a single relay or resistor. The module takes care of all that for you. With that module, it can be a simple truck. Again, like mentioned before, you will need both your keys to program the module. We get away with it here, since I work at a Chrysler dealership, we can use one key or programming with our StarScan scan tool. But, for everbody else who doesn't have one of those, you WILL need two keys. I am very familiar with these trucks, and I just did one just like yours on Saturday. PM me if you need help! Good luck!
green6767
Copper - Posts: 209
Posted: October 30, 2006 at 4:34 PM / IP Logged
I just looked at your bypass kit your bought off ebay. That one WONT take car of the ignition relays/resistors or the factory security. It will bypass your transponder type key and that is all. If all you're going to use is that kit you already have, you may be in for more than you want to tackle. I would HIGHLY recommend you get the CHDL7-pk2, as it will eliminate many headaches!
jacked93
Member - Posts: 17
Posted: October 30, 2006 at 5:09 PM / IP Logged
Does the CHDL7-pk2 kit also bypass all of the resistors for the parking lights, turn signals etc?
Page of 3
Thursday, October 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
