1992 buick lesabre remote start
wil3404
Copper - Posts: 54
Posted: November 30, 2006 at 11:59 AM / IP Logged
I am installing a crimestopper rs900v on my grandmothers car. It is a 1992 buick lesabre. Does anyone know if I need any additional relays to install this unit. I am using the remote starter out of her old car, this is why I am using this unit. I just want to make sure that I have all the needed info and equipment before I start the install. I installed this same unit in my truck last week and it seemed easy enough in that but I think that this buick has a factory alarm that needs bypassed and maybe some other issues. Thanks in advance.
Barnsy
thepencil
Gold - Posts: 1,526
Posted: November 30, 2006 at 12:59 PM / IP Logged
FYI
DIRECTWIRE™ WIRING INFORMATION - BUICK / LESABRE / 1992 / Remote Start
12volts red    +   ignition harness
Starter yellow    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition
Third Ignition
Accessory orange    +   ignition harness
Second Accessory
Keysense
Power Lock lt. blue    +   either kick panel
Power Unlock black    +   either kick panel
Lock Motor gray      drivers door harness
Unlock Motor BLACK/ lt. green      drivers door harness
Parking Lights+ brown      low in drivers kick
Notes: Also found at the lighting control module. The lighting control module is located to the left of steering column.
Parking Lights- dk. blue      light switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white    -   under dash light
Dome Supervision use door trigger
Trunk/Hatch Pin black    -   at switch or light
Notes: Not available on all models.
Hood Pin
Trunk/Hatch Release lt. blue or blk/wht    +   at release switch
Power Sliding Door
Factory Alarm Arm yellow    -   drivers door harness
Factory Alarm Disarm lt. green    -   drivers door harness
Disarm No Unlock
Tachometer PURPLE / white   AC   ignition module
Notes: May also be found white at the instrument cluster on models with a tachometer.
Wait to start
Brake Wire lt. blue    +   brake switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
VATS
Part #: 652T resistor pack
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: See DirectFax document 1049 for interface information.
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Be careful whose advice you buy, but be patient with those who supply it.1992 buick lesabre remote start -- posted image.
wil3404
Copper - Posts: 54
Posted: November 30, 2006 at 4:23 PM / IP Logged
So according to the DEI information I will need to buy an immobilizer bypass ( VATS model# 652t) Is this correct? This looks like the only additional item that I may need to do the install. Any recommendations on where I can pick up one of these bypass units? If you see anything else I should be aware of please advise me. Thanks again!  Jeremy
Barnsy
wil3404
Copper - Posts: 54
Posted: November 30, 2006 at 4:24 PM / IP Logged
The VATS is the chip in the key. Right?
Barnsy
sparkie
Platinum - Posts: 2,061
Posted: November 30, 2006 at 8:25 PM / IP Logged
The black pellet in the body of the key is a resistor. You can use a resistor of the same value and a relay to introduce it into the circuit during remote start.
sparky
wil3404
Copper - Posts: 54
Posted: January 16, 2007 at 8:20 PM / IP Logged
ok so I bought the DEI 652t resister kit. How can I tell what the value in the key is so I can match it? Thank. I took awhile but finally got to this one.
Barnsy
imseth85
Copper - Posts: 71
Posted: January 16, 2007 at 8:40 PM / IP Logged
If you don't want to get into resistor color codes and stuff....just take your multimeter, put it to ohms, and lay it across the little pellet in the key. Make sure you don't touch the leads of the meter or anything, and get a steady reading.
Next, find a resistor with the same (or close) resistance as the pellet.
I really don't want to get into the next step, as it's hard to explain without diagrams, but here's a link that will help you a lot.
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1049.pdf
Seth Alvo     NY
Mobile Electronics Installer
advanced
Copper - Posts: 207
Posted: January 18, 2007 at 1:09 PM / IP Logged
You will need one relay to build that circuit. The easy part is that one of the 15 resistors in your kit will be the right value. It doesn't have to be exact, but it will be pretty close.
Good Enough Isn't!
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
