impala trunk tigger?
alex79
Member - Posts: 16
Posted: March 12, 2007 at 10:20 PM / IP Logged
And the trunk trigger is in a gray 24 pin plug at the BCM and directechs says:
CHEVROLET, IMPALA, 2001, Trunk/Hatch Pin
is one RED / black?????????????
Mike M2
Platinum - Posts: 2,652
Posted: March 13, 2007 at 8:46 PM / IP Logged
I've read this 4 times and still don't understand the question.....
Mike M2
Tech Manager
CS Dealer Services
alex79
Member - Posts: 16
Posted: March 13, 2007 at 9:37 PM / IP Logged
ok mike:i looking in my car the trunk tigger.....
this cable is red-black??
i have impala 2001:
before 8-10 minutes... my system alarm turn byselft why??
false alarm ,in the control screen show open door... but is not open..
mikvot
Gold - Posts: 1,043
Posted: March 13, 2007 at 9:47 PM / IP Logged
That vehicle has a problem with falsing, did you diode isolate the trunk and door triggers?
Mike M2
Posted: March 14, 2007 at 6:35 AM / IP Logged
That's what it sounds like. You gotta place diodes between the alarm and the BCM or it will false...
Mike M2
Tech Manager
CS Dealer Services
Chris Luongo
Platinum - Posts: 3,746
Posted: March 14, 2007 at 8:09 AM / IP Logged
Yes. Another known issue that the tech-sheet people never seem to update.
Cut the car's RED / black wire in half.
Connect a diode to each side of the wire that you've cut......with the band of the diode connected to the "trunk" side, and the other side of the diode to the "BCM" side of the RED / black wire.
Connect your alarm's trunk-trigger input to the "trunk" side of the diode too.
alex79
Member - Posts: 16
Posted: March 14, 2007 at 3:47 PM / IP Logged
hi..Chris Luongo
can i do this same conections.. for tigger doors???....blue and blue-white may be works to....
and tanks for u information.. i sorry man.. but , my english is to bad.. (gramatic) just i have 5 years in usa...
Mike M2
Posted: March 14, 2007 at 6:23 PM / IP Logged
You need to do this for all doors and the trunk to stop falses....
Mike M2
Tech Manager
CS Dealer Services
Chris Luongo
Posted: March 15, 2007 at 12:28 PM / IP Logged
Hey, don't worry about your English. I'm learning Portuguese right now. What country are you from?
And yes, you should do the same with the blue and blue/white door triggers.
If it is easier for you, you can get the door trigger wires at the driver's side fuse box. There is a lot more space there....easier than working at the BCM.
alex79
Member - Posts: 16
Posted: March 16, 2007 at 9:08 PM / IP Logged
yes...   i did...   but, in the bcm...   i not have space,,,,, to tie...........   tanks....   the system is working 100% gooood!
oh.. i from M E X I C O chihuahua... ...
the unlock   not need diode ??? just need resistor for lock....is fine..?
see yaa
