2002 silverado diesel 791xv 457gw problem
downstarinc
Copper - Posts: 119
Posted: April 02, 2007 at 12:13 AM / IP Logged
I worked on a '02 silverado diesed today and I installed the 457gw module that directechs says you need. I hooked up the purple wire to the purple wire on the diagnostic plug (as stated) and i grounded it and gave it 12+. The module is suppose to allow you to grab the door triggers and locks instead of from the bcm but its not working, and the car remote starts but immediately dies. The tach is programed and im sure the problem is in the 457gw module. What am I doing wrong? Thanks!
jl audio..nuff said
Mike M2
Platinum - Posts: 2,652
Posted: April 02, 2007 at 6:36 AM / IP Logged
The 457gw doesn't work the locks on a 2002, only 2003 thru 2007. you will need to connect these directly to the truck right in the fuse box, pretty easy. The 457gw will only bypass the Passlock in your truck...
Mike M2
Tech Manager
CS Dealer Services
Platinum - Posts: 12,488
Posted: April 02, 2007 at 9:15 AM / IP Logged
You can also get the door locks (+) at the BCM as well as the door triggers and parking lights.
KarTuneMan
Platinum - Posts: 7,056
LOCK Lt.blue At Body Control Module   +
 The Body Control Module is located directly below the steering column. Factory security is only available on the LS & LT models.
 UNLOCK White At Body Control Module   +
In the brown plug of the BCM.
another-kelly
Silver - Posts: 618
Posted: April 02, 2007 at 9:35 PM / IP Logged
you didn't mention hooking up the status wire from the 457G
downstarinc
Copper - Posts: 119
Posted: April 02, 2007 at 10:57 PM / IP Logged
thanks for the help guys...cars back in the shop tomorrow so ill see what happens.
jl audio..nuff said
ferretvw
Copper - Posts: 188
Posted: April 03, 2007 at 2:33 PM / IP Logged
yeah i agree with what Another-Kelly said you did not mentian hooking up the status wire which is blue/white on the 457g this needs to go to the blue wire on the 4 connector harness that connects to the remote start relay box. After hooking that up reprogram and it should work fine.
2008 Scion xB
Pioneer AVIC-D3
RF 3Sixty.2 sound processor
Stock speakers (for now ;))
downstarinc
Copper - Posts: 119
Posted: April 04, 2007 at 12:11 AM / IP Logged
well as u might have guessed...it was the status wire that wasn't hooked up...once i hooked it up it was all gravy...thanks guys!
jl audio..nuff said
