adding a power door lock switch
italian_virus
Copper - Posts: 143
Posted: May 14, 2007 at 9:34 PM / IP Logged
Hello all, i have an inquiry regarding the power door lock switch.
Here is the diagram of what i have been trying to connect.
https://img527.imageshack.us/my.php?image=doorlockswitchvk1.jpg
the diodes i am using are 1N4004
the switch i have is 3 pronger middle is ground, the problem i am having is where would i connect the diodes, in the diagram it says the alarm door lock harness.. i have tried that but it did not work ;s should i try where the actuator is ??
Thanks in regards
enice
Silver - Posts: 857
Posted: May 15, 2007 at 1:22 AM / IP Logged
I have this exact setup on my wrangler but dont have any diodes in line and havent had any issues since I did the install a while back.
italian_virus
Copper - Posts: 143
Posted: May 16, 2007 at 2:03 AM / IP Logged
hmm okk i will try it without the diode,
but where did you make the connection from?? the alarm brain or the actuator??
JWorm
Platinum - Posts: 2,208
Posted: May 16, 2007 at 9:28 AM / IP Logged
The switch is just used to trigger the relays. No diodes needed.
italian_virus
Copper - Posts: 143
Posted: May 16, 2007 at 10:00 AM / IP Logged
okk then, so where is it connected from????
btw i have a 95 honda civic so im not sure if the answer may vairy
JWorm
Posted: May 17, 2007 at 12:00 AM / IP Logged
I was under the inpression you added door lock actuators and already have it hooked up to an aftermarket keyless entry/alarm system. Is that not the case? Or do you have an EX Civic with factory power locks?
italian_virus
Copper - Posts: 143
Posted: May 17, 2007 at 7:55 PM / IP Logged
noo
i never had power locks,mine was an civic si. i added the actuators, and i got an alarm.
i was just informed that no diodes are needed. Just attach a switch(3prong) to lock/unlock of the alarm. One is ground and the others are lock/unlock
i am going to try it out and see if it works and let you knoww
italian_virus
Copper - Posts: 143
Posted: July 04, 2007 at 8:46 PM / IP Logged
i just wanted to clarify,
i am going to put a lock/unlock switch on the drivers side, and have nothing on the passenger side. But some people have told me that i am going to need switches on both sides, in order for it to work. i was also told that after i connect the wire from the alarm brain to the switch, i would have to run it to a relay??
im not to sure about it..
if anyone could help it would be appreciated thanks
italian_virus
Copper - Posts: 143
Posted: July 08, 2007 at 4:10 AM / IP Logged
anyone?????
italian_virus
Copper - Posts: 143
Posted: July 11, 2007 at 2:29 PM / IP Logged
ahhh
i am encoutering problems on making this switch work
this is my alarm wiring diagram
https://img520.imageshack.us/img520/2906/p1050682oo3.jpg
i am using
Blue: (-) Instant Trigger Zone 1
Green: (-) Door Trigger Zone 3
There is also
Violet: (+) Door Trigger Zone 3
BUT the connection for Violet is not connected to anything ;s
i have a 3 prong switch and my middle is ground(checked using a DMM)
the ground is connected the chassis
is this correct???
OR am i supposed to be using the green & blue wire's coming from the actuator???
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
