Posted: May 04, 2004 at 9:16 AM / IP Logged
Posted: May 04, 2004 at 10:09 AM / IP Logged
Posted: May 04, 2004 at 1:25 PM / IP Logged
Posted: May 04, 2004 at 5:22 PM / IP Logged
Posted: May 20, 2004 at 4:09 PM / IP Logged
Posted: May 28, 2004 at 9:25 PM / IP Logged
Posted: June 10, 2004 at 6:08 AM / IP Logged
Posted: July 14, 2004 at 2:36 AM / IP Logged
Posted: July 17, 2004 at 9:19 PM / IP Logged
Posted: July 17, 2004 at 9:31 PM / IP Logged
Saturday, May 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
These kits just don't work proper at all with fuel injection. What you want to get is an extra coil, spark plug, small electric fuel pump, NOS fogger nozzle, some braided fuel line, a push button switch (only on when button is depressed) and another switch with a protective flip down cover. You split into your main fuel line and run that to the small pump and from the pump to the NOS fogger which you will insert into the exhaust just before the muffler. You need to drill a hole in the pipe before the muffler and weld a nut there, making sure there is no air leaks. The spark plug will be inserted into the exhaust tip with a drilled hole and a helicoil. mount the coil near the spark plug. Wire it so that when the switch is thrown, power goes to the coil and one side of the push button switch. once you start the spark, push the button which powers the fuel pump and you have flames with no damage to your engine. Let the button go and allow the spark to run for a few more seconds - burns off any excess fuel that drips out. Make sure your fuel line is clear of the exhaust pipe and well insulated against vibration. When you go to turn this on also make sure that your RPMs are pretty high if parked. I wouldn't recommend this for backing off tailgaters, just for good clean fun. thanks- james
. For best results, mount the spark plug and the fogger near the tip.
