momentary to constant with 1s delay
baboonia
Posted: May 19, 2010 at 11:30 AM / IP Logged
I need to trigger a relay with a momentary ground pulse that will keep the relay energized for just 1 or 2 seconds...., then do nothing until the next ground pulse.
Is there an easy way to do this using just a relay/capacitor/resistor/diodes?
A diagram would be helpful. None of the standard drawings cover my exact application.
hotwaterwizard
Silver - Posts: 1,350
Posted: May 22, 2010 at 12:11 AM / IP Logged
https://www.the12volt.com/relays/relaydiagram43.html
momentary to constant with 1s delay -- posted image.
Just use a bigger capacitor
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Platinum - Posts: 13,726
Posted: May 22, 2010 at 6:27 AM / IP Logged
How much current capacity does your momentary trigger provide.  If it is capable of charging a 4700 microfarad capacitor, you can easily do this with the cap mentioned and a diode.  If your output is from some kind of controller, you may need to add a transistor, but still easily done.
dualsport
Silver - Posts: 983
Posted: May 22, 2010 at 2:59 PM / IP Logged
Sounds like he's looking to stretch a momentary input pulse, not applying a constant input, e.g. 100ms pulse input to a 2 second relay closure per pulse.
It'd need a driver circuit to implement if so, a relays only setup won't do.
Prior post with a similar requirement.
