starter kill dei
toolzoneplus
Member - Posts: 16
Posted: June 14, 2013 at 6:27 PM / IP Logged
I am really frustrated and have done this before but can not rember and also I can not find it here on forum but I know it is simple but the 2 black wires coming from the DEI for starter kill relay is not working because I am doing it wrong. I cut the wire from ignition to starter under dash and tested it is correct wire, I am really confused because I have wired the 2 wires from dei (one is the imput to ignition and other is output to starter)to each side and nothing or when you try to start when armed it starts so I hooked to relay as relay images show and now I have tose 2 wires from alarm and no where to go how do we use a relay to go with the 2 wires on dei alarm or now we have 4 wires from under dash 2 from the starter cut and the other 2 from dei and the relay with 4 wires which we can hook up but how to do with this set up
smokeman1
Platinum - Posts: 1,589
Posted: June 14, 2013 at 7:10 PM / IP Logged
Possibly this is what you seek: https://www.the12volt.com/relays/page2.asp
In the Relay section of this site.
toolzoneplus
Member - Posts: 16
Posted: June 14, 2013 at 7:22 PM / IP Logged
Hi that is where I started but has no diagram of the dei unit to relay to starter/ignition
I have the 2 wires coming from the alarm unit for starter kill when armed
I cut ignition wire to starter and now have 2 wires from there
I have a relay with 4 wires coming from this now how do we combine to make it work in with alarm setup
smokeman1
Posted: June 14, 2013 at 7:32 PM / IP Logged
What make and model of remote starter are you using, and which harness and wires are you referring to?
And what vehicle year, make , model...
toolzoneplus
Member - Posts: 16
Posted: June 14, 2013 at 8:48 PM / IP Logged
It is DEI from bestbuy and no remote start just alarm with starter kill and 2 remotes the very basic unit.
2006 Kia spectra
the DEI untit has a plug for 2 wires one for input other for output does not matter which one is used for input or output so I have those 2 wires and cut the ignition wire so now one wire to starter and one wire to ignition and a relay and trying to make it all work togther
Posted: June 14, 2013 at 9:10 PM / IP Logged
DEI ORANGE armed output, A.K.A. GWA wire to 85.
Key side starter wire to 87a.
Starter side to 30.
Ignition 1 + to 86.
Diode 1N4004 from 85 to 86,band side to 86.
Or read my thread on Security and convenience hot topics.
Posted: June 14, 2013 at 9:17 PM / IP Logged
Sorry internal relay, and you've wired it all wrong.
Yellow wire to ignition (actually it's FROM ignition)
Cut starter, GREEN / WHITE to key side, GREEN/ black to starter side don't use green.
toolzoneplus
Member - Posts: 16
Posted: June 14, 2013 at 9:24 PM / IP Logged
What about the 2 wires from alarm? input and output this is from starter to relay which shows on diagrams but I still have those 2 wires from alarm and that is whats confusing me, I tried the orange to 85 which throws a neg .500 when armed I tested it and then the relay wire in middle to starter then the lower 30 to ignition wire and then the one on far right to ignition 12volt when turn key 12 volts and have the diode in place so what about the 2 wires from alarm where do they go
Posted: June 14, 2013 at 9:26 PM / IP Logged
What are the these colours and what model alarm?
toolzoneplus
Member - Posts: 16
Posted: June 14, 2013 at 9:44 PM / IP Logged
the alarm is avital 3100l and has 2 black wires, heavier guage
Page of 3
