Posted: December 28, 2003 at 11:46 AM / IP Logged
Posted: December 28, 2003 at 12:26 PM / IP Logged
Posted: December 28, 2003 at 3:41 PM / IP Logged
Posted: December 28, 2003 at 3:52 PM / IP Logged
Posted: December 28, 2003 at 4:19 PM / IP Logged
Posted: December 28, 2003 at 5:26 PM / IP Logged
Posted: December 28, 2003 at 6:30 PM / IP Logged
Posted: December 28, 2003 at 10:25 PM / IP Logged
Posted: December 29, 2003 at 7:55 AM / IP Logged
Posted: December 29, 2003 at 4:36 PM / IP Logged
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
HER = *NO problem babe*
The flow of water is running full blast now. Then for kicks your GF twists the hose / crimps it.
The water pressure drops, and soon there is no water flow...
You run over to the end of the hose and stick your face in the end of it, while at the same time she lets it rip wide open !!!
You are instantly soaked, and drenched . . .
The pressure was always there, simply impeded for the duration she held the hose.
Whereas if she simply turned the hose at the start and stop, the pressure of water would have built up gradually, and consistently.
The action of her turning the tap handle is the same as you connecting the (-) negative lead to a circuit.
It is the begining of the current flow process, and the stop.
The End . . .
EVIL Teken . . .
