Relay sources
ff-mike
Copper - Posts: 199
Posted: December 07, 2004 at 4:50 PM / IP Logged
Std bosch relays with/without 87a are fairly easy to find. My preferance are actually the ones Western Plow uses as they are hermetically sealed- but they are only 4pin.
What I am looking for is the relays with 2 87 outputs and also the socket-harnesses for 5 pin relays. I know oldsmobile used the dual 87s back in the 80s for their fog lamps
Mike
Sierra2700
Copper - Posts: 117
Posted: December 07, 2004 at 6:57 PM / IP Logged
As a follow up question, where do you guys get Relay's? And do you get relays with the little wiring harness already on it (has a wire coming off each of the terminals? Also what type of relay will I need for a simple "starter kill relay". Is this just a SPDT relay? I am not a dealer, so is there some place besides bulldog security I can buy relay's 1 or two at a time? Sorry to steal your thread :(
boyzWidToys
Member - Posts: 26
Posted: December 08, 2004 at 7:22 AM / IP Logged
where would you find DPDT relays?  for 12 v/30 amp or so?
Is there some part of a vehicle that would use these stock?  I can't find a local supplier for that matter.  I saw radio shack had dpdt 12v 3 amp.  but only in the US not in canada where i am located.
mladams
Copper - Posts: 57
Posted: January 05, 2005 at 2:51 PM / IP Logged
easier then ordering them is just to go to circuit city. inless you want a large bulk of them, in which case you should order.
Matt Adams
Electrical Engineer Major
York College of PA
Chevy Cavy Rally Sport
ak96ss
Member - Posts: 6
Posted: January 06, 2005 at 5:06 AM / IP Logged
I've been pretty pleased with Waytek Wire for a lot of material, from wire to connectors to relays.
http://www.waytekwire.com/
John
mladams
Copper - Posts: 57
Posted: January 07, 2005 at 11:04 PM / IP Logged
does anyone have a good place to get bulk relays with the harnesses. Other bulk supplies would be great to but I'm most interested in relays.
Matt Adams
York College of PA
mobileworks
Copper - Posts: 136
Posted: January 12, 2005 at 6:11 PM / IP Logged
Shameless plug....
$1.49 each SPDT Automotive style relays..
