car stalls when driving
bigcurt
Member - Posts: 9
Posted: July 14, 2008 at 8:26 AM / IP Logged
I can be driving and my 1995 dodge intrepid will stall and sometimes it will start back up but other times it will just crank over. i just put a new coil pack and wires and plugs on it trying to fix the prob but it did not work.deos anyone know what this problom could be?
curtis croskey jr
DYohn
Platinum - Posts: 10,741
Posted: July 14, 2008 at 11:54 AM / IP Logged
Could be a million things.  Sounds like it's time for a visit to an auto mechanic.
jar754
Copper - Posts: 142
Posted: July 14, 2008 at 12:41 PM / IP Logged
is there a check engine light, go to autozone and they can read your codes for free. it could be a crankshaft sensor, or a camshaft sensor
overworked
Copper - Posts: 133
Posted: July 18, 2008 at 10:29 PM / IP Logged
I personally would leaning more towards Crank sensor but yeah man, try an automechanic....
bigcurt
Member - Posts: 9
Posted: July 19, 2008 at 11:17 AM / IP Logged
ok now i have replaced the cranksenser and the fuel pump and the coil pack it runs as of now but it has a hard start to it and i cant find anyone to put a computer on it because everyone has obd 2 and i need an obd 1 connector because they did not do obd 2 in 95
curtis croskey jr
jar754
Copper - Posts: 142
Posted: July 19, 2008 at 12:06 PM / IP Logged
you can do the on off method. insert the key in ignition and turn it to the run position, not crank, and do this on off on off on within 30 seconds and count the number of times the check engine light flashes, for instance 5flashes pause and 1flash means code 51. is the check engine light on, autozone should have an obd1 tester like i said they do it for FREE
overworked
Copper - Posts: 133
Posted: July 19, 2008 at 12:07 PM / IP Logged
What do you mean by hard start?
bigcurt
Member - Posts: 9
Posted: July 19, 2008 at 12:29 PM / IP Logged
hard start it will crank crank then it will fire to start but it seems like it is not fireing on all pistions at first.
curtis croskey jr
jar754
Copper - Posts: 142
Posted: July 19, 2008 at 12:38 PM / IP Logged
are you sure the plugs are gapped right
bigcurt
Member - Posts: 9
Posted: July 19, 2008 at 12:41 PM / IP Logged
i gapped them at 28 what the old ones that were in it that i toook out were at
curtis croskey jr
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
