2003 Toyota Tacoma Alarm/Stereo Wiring
langevin
Member - Posts: 9
Posted: May 03, 2003 at 8:08 AM / IP Logged
Hello and thanks for the great site.  I just found this yesterday and have gone threw it several times already!
I am doing a few new projects with a new 03 tacoma 4x4 reg cab and haven't found anything dealing with the wiring schemes for that year make and model.
Specifically with stereo H.Unit  harness wire colors scheme and the tail light connectors.  Are they both the same as the 2002 tacoma's?
I need help and no-one seems to have the info.
Thanks in advance- Shawn
the12volt
Administrator - Posts: 3,959
Posted: May 03, 2003 at 8:49 AM / IP Logged
Hi langevin, you're welcome and thanks.
I believe it's the same as a 2002, but as always verify each wire with your meter before making any connections. If the colors are different, the polarity and location will like be the same as shown below and should help you locate the correct wires. If you do find any differences, please post your results.
|              12V|white & WHITE/ red   |+  |ignition harness            |
|          STARTER|black               |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|gray *1             |-  |white plug near fusebox     |
|     POWER UNLOCK|purple *1           |-  |white plug near fusebox     |
|       LOCK MOTOR|blue/white          |   |DKP, 12 pin plug in pin 10  |
|     UNLOCK MOTOR|blue                |   |DKP, 12 pin plug in pin 11  |
|    DISARM DEFEAT|blue                |   |PKP, 12 pin plug in pin 9   |
| PARKING LIGHTS +|green               |   |back of fusebox, 12 pin plug|
| PARKING LIGHTS -|PURPLE / red          |   |front of fusebox,22 pin plug|
|       HEADLIGHTS|*2                  |-  |front of fusebox,22 pin plug|
|     DOOR TRIGGER|*3                  |-  |front of fusebox,22 pin plug|
| DOME SUPERVISION|comes on with unlock|   |                            |
|       TACHOMETER|lt. GREEN/ black     |   |instrument cluster or *4    |
|      SPEED SENSE|GREEN/ orange        |4  |ECM behind the glove box    |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blu/blk(L),RED / wht(H|+  |steering column             |
|  LF WINDOW UP/DN|blue - blu/yel      |A  |driver window switch        |
|  RF WINDOW UP/DN|RED / blk - RED / grn   |A  |DKP, 12 pin plug            |
|  LR WINDOW UP/DN|RED / blu - blu/blk   |A  |DKP, 13 pin plug            |
|  RR WINDOW UP/DN|yellow - lt. green  |A  |DKP, 13 pin plug            |
|        RADIO 12V|blue / YELLOW         |+  |radio                       |
|     RADIO GROUND|brown               |-  |radio                       |
|     RADIO SWITCH|gray                |+  |radio                       |
| RADIO ILLUMINATE|GREEN/ red           |+  |radio                       |
|       LF SPEAKER|pink - purple       |   |radio                       |
|       RF SPEAKER|lt. green - blue    |   |radio                       |
|       LR SPEAKER|black - yellow      |   |radio                       |
|       RR SPEAKER|red - white         |   |radio                       |
Notes:
*1 These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.  *2 Vehicles without Daytime Running Lights it is RED / blue. Vehicles with DRL it is RED / green.  *3 The driver door trigger is green, the front passenger door trigger is GREEN / WHITE, and the rear door trigger is YELLOW /GREEN. Use all three wires and diode isolate each.  *4 On the 4 cyl it is at the data link connector to the right of the steering column. On the V6 it is at the igniter on the passenger fender, below the air filter box.
2003 Toyota Tacoma Alarm/Stereo Wiring -- posted image. the12volt • Support the12volt.com
langevin
Member - Posts: 9
Posted: May 07, 2003 at 11:11 AM / IP Logged
Hey 12 volt-Thanks to all your help and info.  The install was a big success!    My Reg Cab Tacoma now has all the bass it can handle paired up with the stock system.  Hell it will not win compititions but makes me quite pleased with the sound I get now.  It even turns heads when I drive by!
Again-Thanks!       Shawn
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
