Eclipse AVN5435
aurora4.0
Member - Posts: 15
Posted: August 12, 2005 at 8:06 PM / IP Logged
Hello all!!  Just had my AVN5435 installed in my 2001 Oldsmobile Aurora with the back up camara and the Sirius sattelite antenna.  Although I love all of my new toys, for some reason my AVN5435 is making a weird sound even when no discs are in any of the drives.  It sounds like something is working really hard on the inside of the unit.
Does anyone have this same problem?  If so, what is it and what did you do about it.
Other than that everything works great..........
aurora4.0
Member - Posts: 15
Posted: August 13, 2005 at 12:21 PM / IP Logged
In addition to the above.... my chimes are real loud and sometimes my chimes stay on when they shouldn't be!!  Any thoughts on what this could be?
Anyone who has had a AVN5435 installed that is having any types of problems.... I would like to know about them!
aurora4.0
Member - Posts: 15
Posted: August 16, 2005 at 6:32 AM / IP Logged
Come on now...... there has to be someone out there that has an AVN5435?
UPDATE: The noise coming from the head unit has gone away........ I'm still a little curious though as to what it could be.   I have a feeling this noise will come-and-go.
gspot35
Member - Posts: 18
Posted: August 17, 2005 at 7:37 AM / IP Logged
The noise you refer to:  Is this with the navigation disc in?  If so you are hearing the Nav compute data and load POI.  As far as the chirps being loud, I have the same problem.  I feel it is because I'm putting a high output amp inline with a factory amp.  I can almost live with it, but I will probably use some sort of adjustable low-high converter in the near future.
aurora4.0
Member - Posts: 15
Posted: August 17, 2005 at 1:19 PM / IP Logged
The Navigation disc is not loaded nor is any CD.  The noise does come and go, so I'm thinking about going back to the installer and getting a new one.  Eclipse says its not a normal characteristic.
I am running a factory Bose Amp so that is probably why my chimes are real loud!!  I can almost live with it too.
Do you have any problems with chimes.... Example: If you start your car with the door open (the chimes will go on).... then close the door....  (the chimes will stay on).
What about when you turn your car off........... does the AVN stay on?  Mine should stay on while the car is off only until I open the door.  But sometimes when I open the door the AVN stays on.  It's a pain in the ass!!
Where did you mount your Navigation transmitter?
aurora4.0
Member - Posts: 15
Posted: August 17, 2005 at 1:25 PM / IP Logged
QUESTION:
I am unable to get titles to display on my new AVN5435.  This is for AM/FM radio stations, also no station call letters.  I know this info is available from my previous radio.  Also CDs from the in-dash player and the CD changer do not display title info. Oddly, the title info does display for MP3s and Sirius. There is a TITLE button on each of these screens, but when pushed, the only thing displayed is a screen with captions indicating where this info should be.  Anyone else experieince this and have you found an answer?
ANSWER:
Funny thing you should ask this question.  I've been wondering the same thing!!!  I was reading up in all 3 manuels because I could of sworn it said something along the lines of, WMA files and CD's could display text.  Did you read anything like that?  All I can get is the MP3 and Sirius to display text too.
eboyer
Member - Posts: 13
Posted: August 17, 2005 at 3:36 PM / IP Logged
I sent the following E-mail to Eclispe...
I rencently had an AVN-5435 installed in my Corvette.  I have some questions which my dealer was unable to answer...
1.  Is there a way to avoid responding to the Navigation "Agree" prompt every time I turn the unit on?  I would be willing to sign a disclaimer in order to avoid this nuisence.
2.  Is there a way to operate the Navigation with guidence and NOT have the Audio mode on?
3.  Is there a setup option to get radio station/title info to display?  The manual says to use the "Title" button, but this does not seem to work.
4.  Can the clock be displayed when both the AUDIO and NAV displays are off?
Here is their response..
Thank you for contacting Eclipse:
The agree message cannot be taken off unfortunately.
You can have the the voice on or off. You have to go into menu on the right side, than setup and on the left side there are scroll arrows. punchdown once and the screen will have the listing: voice guidance in all modes. You can set that on or off.
The radio text only works on the satillite radio or hd radio functions not on fm. It was a big goof on the manuals part. It did not clarify this. The buttons should not have displayed on fm, only hd and satellite.
And unfortunately the time will not come on the navigation and audio off screen. I'm sorry.
Nathan
Avn/Avx
I don't believe the response about the doc error.  That doesn't explain why the screen has a "TITLE" button and when you push it you get another screen with nothing but captions and empty space where the info should be.
eboyer
Member - Posts: 13
Posted: August 17, 2005 at 3:50 PM / IP Logged
Oddly I have a similar noise, sounds like a relay opening and closing, but mine seems to be coming from the CD changer behind the pass. seat.  Also my CD drive in the main unit was DOA, so I had to have the unit replaced the next day.  New unit works great.
My chimes are very loud also, dealer says there is no volume adjustment.  Also all the beeps and chimes sound different but I will get used to them.  I also have the Bose system.
My chimes will sound when I start the car with the door open, but I discovered it is because I have not fastened the seat belt.  If I fasten the belt before I start the car there is no chime.
I do not have any issues with the unit turning off.  It continues to play until I open the door unless I stay in the car too long.  This is working exactly like the factory radio.
stang351w
Silver - Posts: 350
Posted: August 17, 2005 at 8:17 PM / IP Logged
you say there's a noise that sounds like somethings working really hard, i personaly would check the ground for the unit, i've seen bad ground wires do many strange things and make many strange noise's
Tri County KustomZ
certified installer
eboyer
Member - Posts: 13
Posted: August 17, 2005 at 11:16 PM / IP Logged
By DOA, I mean nothing worked in the CD drive.  It would draw the disk in and then displayed a message to check the CD.  I tried this with regular CDs as well as MP3s.
I get title info for MP3s but not regular CDs. I know the CDs contain title info because my old unit displayed the title info.
My CD and DVD drives seem to be about the same speed when loading and ejecting.  I know the DVD goes though a software initialization when you load the Nav DVD, maybe this is why it seems slower.
The one thing I really hate is that I must "AGREE" to the lame warning screen each time I power up the Navigation. Talk about CYA.
Page of 4
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
