2002 Toyota Tacoma Wiring
jellyman
Posted: June 06, 2002 at 8:27 AM / IP Logged
I need a wiring diagram for a 2002 Toyota Tacoma Dbl Cab.  I am trying to install an alarm and i have only found wiring info for 2000 Tacoma. Anyone out there have what I need? Thanks in advance
Platinum - Posts: 12,488
Posted: June 06, 2002 at 8:40 AM / IP Logged
According to my tech notes, the 2002 is the same as the 1998 - 2001 Tacoma.
jellyman
Posted: June 06, 2002 at 8:59 AM / IP Logged
Thanks, another question - the double cab has rear child safety door locks.  See https://www.the12volt.com/doorlocks/page4.asp#tc
does that mean i will need an additional relay setup as shown in the diagram for keyless entry to work properly with the child safety locks?
Zezzar
Member - Posts: 18
Posted: June 07, 2002 at 12:46 AM / IP Logged
yep
Scott35
Silver - Posts: 258
Posted: August 02, 2002 at 9:10 PM / IP Logged
Jellyman, I am in the same situation as you. I have a 2001 Tacoma crew, can't figure out the door locks, If you got your's going, How about straightening me out. Scott
Tacomacrew
dan768
Copper - Posts: 49
Posted: August 02, 2002 at 10:38 PM / IP Logged
The 02 tacoma is different then the 2000. This here is the skinny.
Year(s): 01-02
Make(s): Toyota
Model(s) Tacoma
12 Volt (+)
12ga. WHITE/ Red at ignition harness passing directly behind fuse box
Ignition 1
12ga. BLACK / YELLOW at same
Ignition 2
Ignition 3
Accessory 1
Accessory 2
Starter
14ga. Black at same
Horn
18ga. GREEN/ red (-) at back of fuse box along right edge
Tachometer
Lights (+)
18ga. Green at same at back of fuse box
Lights (-)
Brake Lights
Door 1
18ga. Green (-) at front side of fuse box (wires will actually pass around the fuse box along the right side)
Door 2
18ga. GREEN / WHITE (-) at same
Door 3
18ga. YELLOW /GREEN (-) at same (when equipped with rear doors)
Door 4
Interior Lights
Connect interior light output to driver door pin Green (-), also connect to Door plunger wire GREEN/ Black (-)
Trunk/Hatch
Hood Pin
Trunk Release
Lock (switch)
18ga. BLACK/ Blue (-) at same as door triggers (connect to alarm lock wire)
Unlock (switch)
18ga. RED / Yellow (-) at same (connect to alarm unlock wire)
Driver Unlock
Arm (key)
18ga. Gray (-) (will lock doors) at same as door triggers
Disarm (key)
18ga. Blue/Black (-) at same as door triggers
dan
Remember (there are no hard cars,some just take longer to install on then others)
motman
Member - Posts: 9
Posted: August 12, 2002 at 9:42 AM / IP Logged
That is great help dan, can anyone help me finding the Tach sensor wire.  I can't find the damn thing to save my life.  By the way -  I finally started the install in my 02 Tacoma Dbl cab.  It is not going very well because the previous wiring diagrams i had do not match the vehicle.  Hopefully the one Dan posted will prove to be more accurate.  if anyone else outthere has a more complete wiring setup for the 02 Tacoma Dbl cab please post it.
motman
Member - Posts: 9
Posted: August 12, 2002 at 10:02 AM / IP Logged
Also,
Does anyone know what location and color the child safety lock wire is?
JayBrown1
Member - Posts: 10
Posted: August 15, 2002 at 6:10 PM / IP Logged
The wiring info Dan posted is correct except for the start wire (actually black at ign switch and BLACK / YELLOW behind fuse box.  Test with a meter to confirm while cranking) and the IGN wire for the igniter and such is BLACK/ red.  The tach wire is light GREEN/ black at ECM in the white 28 pin connector or you can tap it at the diagnostic conector on the drivers side under the dash by the center console.
The Tacoma does not use a double unlock signal for doors other than the drivers door.  Most Toyota's with factory, not port or dealer installed, do use this system(i.e. Camry, Avalon).  You may be thinking of the little mechanical locks on the rear doors near the lock that prevent opening the doors from the inside that are also called child safety locks.  My D-cab with the port installed security system does have this feature, but it is part of the control module and wiring for that add-on system.
Hope this helps.
Sunday, May 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
