How can I fix this circuit?
eloshdesign
Member - Posts: 15
Posted: March 29, 2002 at 6:26 PM / IP Logged
Please take a look at the attached diagram. The manual rocker switch was hooked up and worked fine. When I added the dual relay circuit (for remote control) the fuse at the switch would blow when I pressed up or down on the switch.
I can have either remote control or manual control, but not both at the same time. Looking at the diagram, why is this happening and how can I fix it so both methods can get along?
The pulse stretcher is not actually hooked up yet.
Thanks,
DarenHow can I fix this circuit? -- posted image.
the12volt
Administrator - Posts: 3,957
Posted: March 29, 2002 at 11:08 PM / IP Logged
Hi eloshdesign, the fix is simple, you need to cut each lead from the switch to the actuator and connect 87a to the switch side of the respective actuator lead and connect 30 to the motor side of the respective actuator lead.
the12volt
the12volt
Posted: March 29, 2002 at 11:17 PM / IP Logged
BTW, if you need me to draw a diagram of the workling circuit, just let me know.
the12volt
delosh
Posted: March 30, 2002 at 12:30 AM / IP Logged
I would love a diagram. Could you please do one up for me?
Thanks,
Daren
delosh
Posted: March 30, 2002 at 8:31 AM / IP Logged
I read it again today…it's much clearer now.
Note to self: Do not try to figure out electronic circuits AFTER the neighbors come over for drinks.
Thanks!
Daren
the12volt
Posted: March 30, 2002 at 10:49 AM / IP Logged
Hi Daren, here ya go:
Let me know if you need anything else.
the12volt
eloshdesign
Member - Posts: 15
Posted: March 30, 2002 at 12:24 PM / IP Logged
Thanks for the diagram.
I wired it just like you have it in the above diagram, but the actuators don't move via the alarm remote. The manual switch works and the 30's light up my test light via the alarm remote (when the test light is grounded to the chassis). Are the actuators not getting ground somehow when activated vis the remote?
the12volt
Posted: March 30, 2002 at 1:09 PM / IP Logged
Hi eloshddesign, measure resistance to ground on each actuator lead at the actuators. If they are not resting at ground with nothing activated, then I'd suggest rewiring your switch so the actuators do rest at ground or even wire the switch to activate the coils of the relays to control the actuators.
the12volt
eloshdesign
Member - Posts: 15
Posted: March 30, 2002 at 1:15 PM / IP Logged
Would it be possible to do another diagram that shows the above options? It's a little unclear to me about "resting at ground". Does that mean the switch needs to grounded all the time?
the12volt
Posted: March 30, 2002 at 1:29 PM / IP Logged
Here's a diagram showing the switch activatiing the coils of the relays to control the actuators.
the12volt
Saturday, August 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
