Power problem
bigherm033
Member - Posts: 38
Posted: April 18, 2004 at 7:22 PM / IP Logged
I have a 95 maxima. well i haven't been able to test the fuses b/c none of them will light up so i and none of them have been blown. . I have checked ever fuse in my car and replaces every fusible link. Still my radio, power locks, power window, and clock don't work.
ck auto
Copper - Posts: 257
Posted: April 19, 2004 at 2:08 AM / IP Logged
hi what is your battery voltage and what do your cables look like i seen cable look good and votage on the end of cable but resistance so hi nothing substantial getting through
good luck
kirk
bigherm033
Member - Posts: 38
Posted: April 19, 2004 at 5:53 PM / IP Logged
wow, can you speak so where i understand it?? hahahah
flynntech
Copper - Posts: 275
Posted: April 25, 2004 at 4:17 AM / IP Logged
I mean no offense by this, if you are replacing fuses without even looking at them or checking them, troubleshooting an electrical problem isn't something you will learn to do overnight.
a fuse will pass current and open when the current exceeds it's rating.
most fuses have exposed contacts on each end to allow you to test it.
0 volts with a meter means it's good, or 0 ohms...although I wouldn't do too many resistance checks on powered circuits.
you can even use a test light! if it lights.....then you have an open fuse (if the rest of the circuit is closed)
anyways....your problems are obviously not in the fuses, so I will recomend some suplemental reading:
haynes manual for your car....read section on electrical troubleshooting.
buy a multimeter.....read the instructions for the multimeter
infact...those two things will pay for themselfs, probably within this first fix.
