290i-c command start
majorj13
Member - Posts: 12
Posted: December 29, 2002 at 12:27 AM / IP Logged
I just got a new 290i-c command start, I was wondering if anyone would have the wiring guide and step by step wiring instructions, also a wiring guide for a 1992 olds cutlass cierra. Thanks in advance
majorj13
Member - Posts: 12
Posted: December 29, 2002 at 11:20 AM / IP Logged
My main concern is what wires do I hook the 30amp fuse to??
Platinum - Posts: 12,488
Posted: December 29, 2002 at 11:36 AM / IP Logged
If it's like any other CS model, you hook up the fuses to the RED and the RED / BLACK wires.
majorj13
Member - Posts: 12
Posted: December 29, 2002 at 12:00 PM / IP Logged
This is my fisrt install on a CS model, I have done 3 or 4 Auto Commands, I got this Cs 290i-c for christmas and am trying to put it in wifes car but I need install instructions for the cs290i-c and a wiring guide for a 92 old cutlas ciera
Any help would be greatly appreciated thanks
wade
majorj13
Member - Posts: 12
Posted: December 29, 2002 at 5:36 PM / IP Logged
where does a guy hook the tach wire to????
Posted: December 29, 2002 at 9:06 PM / IP Logged
Here is a CS diagram for another model, but CS has had the same wiring harness for the past 6-8 years: Command Start CS310i.
Wiring information for the Olds:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |drivers kick                |
|     POWER UNLOCK|black               |+  |drivers kick                |
| PARKING LIGHTS +|brown               |   |light switch                |
|       HEADLIGHTS|yellow              |+  |light switch                |
|     DOOR TRIGGER|white               |-  |underdash lt, ctsy lt       |
|  TRUNK/HATCH PIN|gray                |-  |at light (wagon only)       |
|TRNK/HTCH RELEASE|black               |+  |release switch              |
|       TACHOMETER|PURPLE / white        |   |distributor/coil pack*1     |
|       BRAKE WIRE|white               |+  |brake switch                |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |wiper switch                |
|  LF WINDOW UP/DN|dk.blu - brn        |A  |in drivers door             |
|  RF WINDOW UP/DN|dk.blu/wht - tan    |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|dk. grn - pur       |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|lt. grn - pur/wht   |A  |in drivers door or dkp      |
Notes:
*1 Some coil packs rear of engine above transaxle.
majorj13
Member - Posts: 12
Posted: December 29, 2002 at 11:11 PM / IP Logged
great thanks, I got every thing hooked up, Now when I push the remote to start the car it starts but starter keeps cranking, why is this???
Thanks again
Posted: December 30, 2002 at 8:41 AM / IP Logged
You do not have the tach wire properly programmed. When CS makes the units it is set for 6 cylinder mode. You will need to program it for 4 cylinder mode.
majorj13
Member - Posts: 12
Posted: December 30, 2002 at 9:21 AM / IP Logged
I left it a factory settings, and the car is a 6cyl, I hooked tach wire to the white wire on the coil pack
Posted: December 30, 2002 at 9:25 AM / IP Logged
Is there a PURPLE / WHITE wire in the same plug that you can tap into ?
Page of 3
