sirius, 99 sts
Ikillrinst
Member - Posts: 34
Posted: May 27, 2008 at 1:01 PM / IP Logged
i am sure i already know the answer to this one but just wanted to be sure before i ruin anything...
I recently purchased Sirius sat radio for my 99 STS.. the antenna wires are all super long and were easy to hide but the power cord is really short and i hate the idea that you have to see it and that you have to remember to shut the reciever off each time you exit..
question is.. can i cut the end off that goes into the cigarette lighter and wire it directly to the fuse box without hurting anything? this way it will turn off when the car is turned off
collyn eastham
Member - Posts: 27
Posted: May 27, 2008 at 1:46 PM / IP Logged
No. The lighter adapter is stepping the voltage down to 5 volts. You will definately ruin the Sirius tuner with more than the 5 volts it's designed for. Just get a lighter socket adapter and then wire the + lead the acc or ignition 12 volts at the Caddys steering wheel harness and ground the - lead to chassis.
Collyn Eastham
a.k.a. 300MBQuart
08 HHR Panel
Ikillrinst
Member - Posts: 34
Posted: May 27, 2008 at 2:10 PM / IP Logged
collyn
thanks, i was going to ask about the lighter socket hard wiring as you suggested but the text area froze and would not let me type the rest of my post...  Thanks again
