what subs for spl?
akickz
Copper - Posts: 72
Posted: June 24, 2008 at 2:29 AM / IP Logged
looking for some subs that will give me a high spl. right now im running 4 alpine type-r's on 2 jl audio 1000/1's. was going to upgrade to two mtx te1501d amps, was entertaining the thought of getting sum new subs but not sure which. just wanted to see what different subs people have dealt with.
either new subs or i was going to run the te1501d on my type-r's, they push 1500 watts at 1 ohm, my cousin has that setup with the type-r's and those amps.
forbidden
Platinum - Posts: 5,354
Posted: June 24, 2008 at 1:34 PM / IP Logged
Digital Designs and the proper custom slot port box will deliver the results that  you are looking for.
theterminator
Copper - Posts: 96
Posted: June 24, 2008 at 1:58 PM / IP Logged
no offense but i wouldnt consider that MTX amp an upgrade from the JL. In terms of sound quality. Remember that doubling your watts can only gain you 3dbs. A properly built box can gain you as much as 10 dbs. Some subs i would reccomend is Fi audio, TC Sounds/Audiopulse, Digital Designs, RE Audio, Orion.
sedate
Silver - Posts: 1,173
Posted: June 24, 2008 at 4:11 PM / IP Logged
what subs for spl? -- posted image.
MTX does NOT make an "upgrade" for the JL1000/1.
I think the JL1000/1 can put something like 1600 watts into a nominal 4-ohm, reactive load.
jmelton86
Gold - Posts: 1,228
Posted: June 24, 2008 at 6:49 PM / IP Logged
What enclosure are the Type-R's in? I mean, you've got 4 of some of the best bang for the buck subs.
I bet if you'd build a nice ported box tuned to about 35Hz, it would blow your mind.
WAY cheaper than new subs, or amps!
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
aznboi3644
Gold - Posts: 2,600
Posted: June 24, 2008 at 7:25 PM / IP Logged
To his question...please do not answer sealed.
There are people doing 150's with single Type R's.
Four of them should get quite loud
megaman
Copper - Posts: 385
Posted: June 24, 2008 at 7:35 PM / IP Logged
JL 1000/1 amps are fully regulated.  1000 watts at 1.5 - 4 ohms.  whatever you hook up, you're gonna get 1000 watts.
sedate
Posted: June 24, 2008 at 9:47 PM / IP Logged
Right right sure sure.
I saw a test bench result a few years ago that pegged the amp at something like 1600 watts - but go figure I can't find it now.
Regardless - replacing a JL1000/1 with anything MTX makes is - uhh - silly.
theterminator
Copper - Posts: 96
Posted: June 24, 2008 at 10:01 PM / IP Logged
It is fully regulated but it could be fully regulated putting out 1600w at 1.5-4 ohms. I totally agree with sedate about mtx being even considered an upgrade. If you want to upgrade then look into some of Robert Zeffs amp aka Arc Audio and Zapco. Also Audison, Alpine, Eclipse, and McIntosh.
akickz
Copper - Posts: 72
Posted: June 24, 2008 at 11:41 PM / IP Logged
Ok to answer some questions.
the only reason i was going to switch to the mtx amps is because my cousin has them pushing 750 watts to each type-r and they are balls out loud.
I also tried a little experiment and put two type-r's in a 4.5 cubic ft enclosure ported at 35hz, 1 type-r to each jl amp, played for a bit until i turned the gain up too much on 1 amp.
but right now the 4 type-r's are in a box that has about 3 to 3.5 cubic feet each chamber for each 2 subs, ported at 35hz. I want to go louder though. the only thing is the box wasn't built to spec for my car the box was built for a Lexus ls400 with four 1200 watt pioneer subs.
but to aznboi3644 thats crazy hitting 150 with a single type-r.
