h/u pre amp voltage vs amp input voltage
monorail
Member - Posts: 22
Posted: March 25, 2010 at 3:44 AM / IP Logged
I have an older amp with an input voltage rating of 500mv. I'm looking at a newer H/U with a pre-amp of 2V. Is this doable or do I need to upgrade the amp too?
oldspark
Gold - Posts: 4,913
Posted: March 25, 2010 at 3:59 AM / IP Logged
So you need to reduce 2V to 0.5V....
What a blessing!
It might be as simple as a 4:1 resistor/voltage divider...
IE - for 10k-Ohm impedance - 2V into 7.5k & 2.5k series connected resistors (with 2.5k on GND side) and the 0.5V out from the 2.5k.
Platinum - Posts: 13,725
Posted: March 25, 2010 at 5:56 AM / IP Logged
The amplifier has a gain control knob, simply turn it down a bit.
monorail
Member - Posts: 22
Posted: March 26, 2010 at 9:49 AM / IP Logged
So it's that simple? There will be no damage to the amp?
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 26, 2010 at 9:55 AM / IP Logged
It won't damage the amp. Here's a link that explains it in detail: http://www.bcae1.com/preoutv.htm
Posted: March 26, 2010 at 9:01 PM / IP Logged
It is that simple, and no it will not damage your amplifier.
monorail
Member - Posts: 22
Posted: March 27, 2010 at 12:12 AM / IP Logged
Thanks much guys!
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
