enclosure ideas for 2 12 kicker l7's
certifiedsoundz
Member - Posts: 6
Posted: January 22, 2011 at 1:14 AM / IP Logged
Hi all, i just bought 2 kicker l7s off ebay, and it came in a crappy sealed box. i need some enclsoure dimension ideas for a ported box.
they are going to be in a 1997 4runner. i want them facing the rear(sub/port). i want them in their own chambers(so 2 seperate ports),
the subs are dual 2 ohm each, and is going to be powered by a kicker 2500.1 amp down to 2 ohms stable.
please help me out with some ideas.enclosure ideas for 2 12 kicker l7's -- posted image.
thanks
certified soundz hawaii
2 12" kicker l7
kicker 2500.1 amp
JL 600/4
alpine type x 6.5/ 5.25 components
j.reed
Copper - Posts: 716
Posted: January 22, 2011 at 1:37 AM / IP Logged
I would go with 2.5 cu.ft. NET. Port at 33 square inches of port are and 16.5 inches deep (per sub).
port volume will be .32 cu.ft. So each chamber needs to be 2.82 cu.ft.(Not including any internal bracing)
5.64 cu.ft. GROSS internal for the total enclosure(not figuring internal bracing).
Thats a good amount of power for those subs. They will handle it if your smart with it. You will not want to do the larger recommended enclosure with that kinda power. Also in your vehicle that enclosure and tune should be plenty loud and clean.
certifiedsoundz
Member - Posts: 6
Posted: January 22, 2011 at 1:48 AM / IP Logged
@j.reed
Thank you so much for the reply.. im kind of a noob at this stuff enclosure ideas for 2 12 kicker l7's -- posted image... you think you could post up a sketch of the lengths of the sides and stuff?
i got 38" width of trunkspace to give if that helps xp
2 12" kicker l7
kicker 2500.1 amp
JL 600/4
j.reed
Copper - Posts: 716
Posted: January 22, 2011 at 2:14 AM / IP Logged
I can, but it is late right now and im headed to bed. If i have time tomorrow i can. Give me your max length as well.
certifiedsoundz
Member - Posts: 6
Posted: January 22, 2011 at 1:06 PM / IP Logged
16".. i dont want it too close to my back door
2 12" kicker l7
kicker 2500.1 amp
JL 600/4
j.reed
Copper - Posts: 716
Posted: January 22, 2011 at 3:22 PM / IP Logged
your looking at it being like 21 inches tall then and not really ideal from what I remember of those 4 runners.
certifiedsoundz
Member - Posts: 6
Posted: January 22, 2011 at 4:36 PM / IP Logged
well the max i would go is 23..
2 12" kicker l7
kicker 2500.1 amp
JL 600/4
certifiedsoundz
Member - Posts: 6
Posted: January 22, 2011 at 4:40 PM / IP Logged
max length*
2 12" kicker l7
kicker 2500.1 amp
JL 600/4
j.reed
Copper - Posts: 716
Posted: January 22, 2011 at 8:43 PM / IP Logged
This would get you done just fine. Enclosure outside dimensions 36"W x 14.75"H x 23"L. The port is 2.5"W x 13.25"H x 16.5"L
You could also do external of 38"W x 14.75"H x 21.75"L with the same port. If it will fit better. Both will put you right on your target 2.5cu.ft NET per sub. Need anything else just let me know.
certifiedsoundz
Member - Posts: 6
Posted: January 26, 2011 at 9:16 PM / IP Logged
thank you so much!.. i built it today it sounds great! i post pics up later...
if i wanted to make a fiberglass blox.. would i use the same 5 sides besides the front?
2 12" kicker l7
kicker 2500.1 amp
JL 600/4
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
