factory stereo, chevy equinox
Thack79
Silver - Posts: 526
Posted: January 24, 2011 at 8:39 AM / IP Logged
Does the factory amp just control the 8 inch sub and the 4 other speakers are power by the deck?
Symptom:
No sound in front left speaker and a grouding alternating noise in the front right speaker (i have changed all four speakers and same issue)
Im pretty sure the factory deck is just blown, however the dealer told them they have to replace the factory amp which i just dont believe because most factory amps JUST do the subs.
Any suggections???
Mike M2
Platinum - Posts: 2,652
Posted: January 24, 2011 at 6:33 PM / IP Logged
On a GM product the amp generally powers the entire system(as does Honda, Toyota, Chrysler, Nissan). If i had to guess i'd be pointing towards the amp too...
Mike M2
Tech Manager
CS Dealer Services
Platinum - Posts: 13,725
Posted: January 24, 2011 at 7:21 PM / IP Logged
GM radios are pretty much bulletproof.  Their amps, not so much.
yimke
Copper - Posts: 417
Posted: January 24, 2011 at 10:40 PM / IP Logged
Especially the Tahoe/Suburban amps. Spill a drink in your center console, and you are SCREWED!
Thack79
Silver - Posts: 526
Posted: January 25, 2011 at 7:18 AM / IP Logged
can i do i rewire around the amp? is the Gm deck capable of playing around the amp or do i need to get an aftermarket radio installed?
Mike M2
Posted: January 25, 2011 at 5:02 PM / IP Logged
It will only play low volume without the amp. You can bypass the amp with an aftermarket radio, but if it were mine i would be checking Ebay and junk yards for a used amp....
Mike M2
Tech Manager
CS Dealer Services
Thack79
Silver - Posts: 526
Posted: January 26, 2011 at 7:21 AM / IP Logged
thanks Mike....
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
