97 Montero Sport
brianh
Silver - Posts: 518
Posted: August 25, 2002 at 8:30 PM / IP Logged
I have a 1997 Montero Sport and I am trying to find the factory amp so I can bypass it.  I also have a question about the power antenna.  It recivies power from the factory  radio.  Can I just use a relay to feed it 12 volts using the ant lead off of the cd player?  This vehicle has the infinity sound system and there are no speaker wires be hind the radio, they are at the amp.  It seems that the amp is feed a signal by a speacial cable straight out of the radio.  Any help would be most helpful.                brianh
Bishopbg
Posted: October 07, 2002 at 7:19 PM / IP Logged
On My '98 the amp is in the back panel right above the right tire. It's a pain to get to but all the speaker wires are there so you can bypass the amp if you want to.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
