How to get 14 volts
vdubmk4
Copper - Posts: 175
Posted: August 10, 2004 at 10:48 PM / IP Logged
What do i need to get to send 14.4 volts to my amps ? New battery ? or does it have to do with the alternator ?
Fortune: You will continue to take chances, and be glad you did.
switch_hitter
Copper - Posts: 151
Posted: August 10, 2004 at 10:50 PM / IP Logged
You need to upgrade your alternator
switch_hitter
Copper - Posts: 151
Posted: August 10, 2004 at 10:51 PM / IP Logged
you need to upgrade your alternator
vdubmk4
Copper - Posts: 175
Posted: August 10, 2004 at 11:00 PM / IP Logged
To one that puts our more amperage ? or is there a higher volt rating ? will it affect my other components, like fry em ?
switch_hitter
Copper - Posts: 151
Posted: August 10, 2004 at 11:17 PM / IP Logged
you need to get one that put out a higher amperage, it won't hurt anything...just make your electrical system stronger...remember up grade your power and grounds coming from your alternator to 4 guage.
haemphyst
Platinum - Posts: 5,059
Posted: August 11, 2004 at 12:35 AM / IP Logged
when the car is running, you are (or should be) getting 14.4 volts. this is the voltage you should be seeing at the battery terminals, because this is the nominal charge voltage for a 12 volt battery. if you are NOT seeing 14.2 to 14.4 volts, it is likely that you do not have enough alternator to keep up with your existing accessory load, and you should then upgrade your alternator. put in the highest current one you can afford (and that will fit)
powerhx2
Member - Posts: 13
Posted: August 11, 2004 at 1:06 AM / IP Logged
what if u see 14.4 and another day u c 13.7
kvt-911dvd
2 Autotek Stealth xs.1500's
2 yellow top
2 MTX 3'' 2 ways
2 6x9 alpine type r's
2 15's poweramper xp^2
alpine mrv-f407 4 channel
150 amp anl fuse
switch_hitter
Copper - Posts: 151
Posted: August 11, 2004 at 7:05 AM / IP Logged
then you need to continue to upgrade...either wire guage, or get even a bigger alternator, but like haemphyst said, just get the biggest one you can, and then you will be good to go
customsuburb
Gold - Posts: 1,813
Posted: August 11, 2004 at 9:09 AM / IP Logged
13.8 volts is the average voltage at the battery.
archemedes
Copper - Posts: 172
Posted: August 11, 2004 at 12:34 PM / IP Logged
14.4 is what the alternator should put out when running, under 14 volts and the alternator doesn't meet specs (as a mechanic when we saw under 14 volts while running we had to run a load test)
