Factory Sub
cnschweg
Posted: July 25, 2005 at 11:36 AM / IP Logged
I was told I could use the factory inputs to the factory sub amp on an aftermarket amp, as long as I put rca ends on them. I'd run a new power lead, but would like to use the factory signal wires if possible. does anyone know which wires these are? Thanks
Craig---
JAydawg21
Copper - Posts: 51
Posted: July 25, 2005 at 12:14 PM / IP Logged
well, if your using the wires that acctually connect to the sub itself, you either need to buy an amp that has a high voltage input, or buy a live converter to step down the signal.  The signal that appears across the acctuall speaker terminals has already been amplified and is too large for standard rca inputs which are typically around 4 - 5 volts
'97 Jeep Cherokee sport
subs: JL 12w3v2 : RF 500a2 :
RF 1F capacitor
doors: 6" Diamond D361i -> RF 200a4
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
