Dual batteries
adix5689
Member - Posts: 24
Posted: July 29, 2005 at 10:08 PM / IP Logged
 My system is a total of 3500watts. I have a 170amp alternator. Will the alternator and two batteries be enough to power 4 alpine mrd-605s , one mrv-f545 and a mrv-f345 3 monitors and the dva-9560.  What brand of batteries should I use. I was reading the forum and some people siad auto zone batteries were good. I just bought a new auto zone battery. Could a buy another autozone battery and put it in the trunk.
Blowntweeters
Silver - Posts: 650
Posted: July 29, 2005 at 10:20 PM / IP Logged
for the trunk i would recommend a kinetik battery www.kinetikaudio.com of if you don't want to spend that much i would suggest the optima yellow top also you may want to look into an alternater that is more like 300 amps for the amount of power you are running that would be a better match
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
godd dan it
Copper - Posts: 447
Posted: July 29, 2005 at 11:29 PM / IP Logged
A second battery will only allow you to run your electrics of the car longer while the engine is off. It doesnt give you any extra power. If you experience any dimming lights and etc., then upgrade your alternator to a higher output.
speedwayaudio1
Silver - Posts: 879
Posted: July 30, 2005 at 4:20 AM / IP Logged
only use a sealed batt in the trunk. I run 2- 1000amp duralast batts,but they are both under the hood.
Big Dave
adix5689
Member - Posts: 24
Posted: July 30, 2005 at 10:14 AM / IP Logged
I have a 2001 honda civic and the biggest alternator I can find is a 170amps. Does any one know where I can get a bigger one. I got mine from 4alterstart.com.  Do they make a 300amp alternator that bolts in the factory location.
Blowntweeters
Silver - Posts: 650
Posted: July 30, 2005 at 10:19 AM / IP Logged
check www.highoutputalternaters .com   is the 3500 watt figure RMS or peakpower ? and did you install everthing already ?
adix5689
Member - Posts: 24
Posted: July 30, 2005 at 8:54 PM / IP Logged
No I have notinstalled anthing in the trunck yet. I just finish inside the car now Iam going to do my trunk.  I was going to go with 3 10inch alpine subs and 3 mrd-605s. The mrd-605 is 400watt x 1 at 4ohms or 600watt x 1 at 2ohms. Iam not going to be pushing them tthat hard. Inside the car I have a 5.1 system. If I use 3 10inch subs at 4ohms that would be 1200watt + 800watts for the multi channel amps thats 2000 watts. I should be able to power everything with a 170amp alternator.
Blowntweeters
Silver - Posts: 650
Posted: July 31, 2005 at 12:23 PM / IP Logged
with the rms power you are running that alternator and a kinetik battery will work the kinetik batterys are the best on the market for car audio use
haemphyst
Platinum - Posts: 5,059
Posted: July 31, 2005 at 1:29 PM / IP Logged
That's as big as you're gonna ever find, too... I have the same car, and it's all I could locate in over 6 months of searching. That, BTW, is where mine came from too... Good alternator, but make sure you have a 4 gauge from it DIRECTLY to the battery, or you will never get the full capacity of it. I did quite a bit of underhood wiring modification for that kind of ampacity... PM me if you'd like specifics.
Master Asylum
Silver - Posts: 400
Posted: July 31, 2005 at 1:52 PM / IP Logged
hae, what if the wire was wired to the accessory block or whatever(where the original wiring goes I believe)? Maybe that is the problem with the alt I got from them. It'd be great if they told me that this might be a factor, but they also approved of the install and testing the mechanic did locally and wanted it sent back. If this matters significantly I may try it...
1998 Monte Carlo w/
Eclipse CD8454
2xRockford 5.25" Power 2-way T152C
2xRockford 6"x9" Punch 3-way FRC4369
1xMemphis 16-MCH1300 5-channel
2xKicker 12" L5 Solobaric-2 Ohm
