How to make Sound Deadener?
jl_jeep19
Posted: January 09, 2006 at 5:09 PM / IP Logged
i was wondering if anybody knew how to make sound deadener ?
1 JL-W3 2 Phoenix Gold Amps + Bass Cube
kirktcashalini
Silver - Posts: 492
Posted: January 09, 2006 at 6:46 PM / IP Logged
yeah you dish out hundreds, maybe thousands for dynamat, or search ebay for slightly less expensive stuff that is probably just as good. How to make Sound Deadener? -- posted image.
jfunk06
Copper - Posts: 64
Posted: January 09, 2006 at 7:00 PM / IP Logged
Basicly consists of asphalt, rubber type material, aluminum cover, or a combination of all of them.  Basicly, you can find a less expensive way that works for you, or spend about 120% of your audio budget on deadening
Govenor of Jimcinati
93' GMC Safari XT
electrostatic
Copper - Posts: 154
Posted: January 09, 2006 at 7:26 PM / IP Logged
is your goal to reduce road noise, panel vibrations or both? as a general rule increasing mass lowers resonant frequency, as does increasing rigidity of panels. ensuring your weatherstripping is in good shape will help with road noise.
memphis11223344
Member - Posts: 34
Posted: January 10, 2006 at 10:15 AM / IP Logged
you can go to your local home depo or lowes. they have this stuff that they use on your air conditioning lines so they reduce moister. its like a tar like matrial. its very cheap and does the job great. i have a 03 durango and i used it on my roof and back panals and it works like a dream. huge difference. i think i paid like 70 bucks for everything. deff try that before spending an arm and leg on dynamat. theres this other stuff called b-quite you can find it on ebay its real cheap to and its the same stuff.
6 memphis PR 15's sealed enclosure. indash mobile video system. alphasonik HC800PMA 3000 rms
MECP first class installer
speedwayaudio1
Silver - Posts: 879
Posted: January 10, 2006 at 10:19 AM / IP Logged
Spray on truck bed lining works very well.
Big Dave
stevdart
Platinum - Posts: 5,816
Posted: January 10, 2006 at 11:12 AM / IP Logged
jl_jeep19, if you were capable of manufacturing your own you wouldn't be asking how to do it on an internet forum.  Buy it like everybody else does.
flynntech
Copper - Posts: 275
Posted: January 10, 2006 at 4:57 PM / IP Logged
I would agree, people have been using 'peel'n seal' forever. Moat of that stuff will do the trick. Dynamat is nice, but for the money it's a little overboard.
downstarinc
Copper - Posts: 119
Posted: January 10, 2006 at 10:29 PM / IP Logged
get a job at best buy, employee discount for dynamat is amazing...
jl audio..nuff said
memphis11223344
Member - Posts: 34
Posted: January 11, 2006 at 9:58 AM / IP Logged
yea it is. i do the in the mobile install at best ive been there for 3 years and for a x-threme bulk pack its only like 34.87 when normaly its 93.99. but if you dont want to go that route then go on ebay and type in dynamat and get this stuff called b- quite it works like a charm. just make sure yo uhave a heat gun
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
