power but no sound 99 camry, pioneer dek
stalt
Member - Posts: 23
Posted: March 09, 2006 at 9:08 PM / IP Logged
Hey all,  I think the deck is bad, but maybe I am missing something.
Have a 99 camry and had a Pioneer DEH-P4400 in it.
Just got a DEH-P6700MP.  Got a new wiring harness soldered it up and stuck it in...The Unit poweres up but no sound.  EQ shows deck is picking up sound when in both CD and Tuner modes.
Put the ond deck back in and it works....rechecked all solders and retaped to be sure no stray wires were sticking out and tried it again....Same thing. Power but no sound.
Thoughts?
Stalt
mad550
Copper - Posts: 201
Posted: March 09, 2006 at 9:22 PM / IP Logged
Check car for shorts specifically in the rear speakers
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
geepherder
Platinum - Posts: 3,668
Posted: March 09, 2006 at 9:26 PM / IP Logged
You need to power up the factory amp.  Connect the blue wire in the aftermarket harness to the new radio's blue/white wire.  Some Toyotas have the amp below the factory radio and you can simply unplug the amp, and plug in your new stereo there, effectively bypassing the amp.  Your's should be behind the glove box.
stalt
Member - Posts: 23
Posted: March 09, 2006 at 9:48 PM / IP Logged
I didn't have the blue wire connected with the 4400 and everything works fine....is there a reason it is required with this new amp?
Stalt
stalt
Member - Posts: 23
Posted: March 09, 2006 at 10:46 PM / IP Logged
Checked the harness in the car and there are no wires into the 2 spots where the blue wire would connect, so Guessing that is notthe issue.
Any other suggestions?
Stalt
ophidia31
Copper - Posts: 78
Posted: March 09, 2006 at 11:21 PM / IP Logged
do any of the speakers pop when you turn the radio on? ive found that some stereos do that and it leads to a shorted speaker somwhere. other wise it might be the radio itself. disconnect the 4 speaker hookups and try hooking and external speaker up (if you have one laying around) a house speaker would do if its not 2ohm. if there still isnt any sound then its a bad deck.
kgerry
Platinum - Posts: 3,455
Posted: March 10, 2006 at 9:08 AM / IP Logged
disconnect the speaker laeds and hook up a test speaker to the wires coming from the deck... does the test speaker work? if no, you likely have a blown O/P in the HU... if it does you likely have a short in the wiring... grab a meter and meter every speaker wire for continuity to ground... if you get a reading then that wire is shorted to ground... test them all..... it's unlikely this is the problem if the 4400 works fine....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Ravendarat
Platinum - Posts: 2,806
Posted: March 10, 2006 at 9:51 AM / IP Logged
Is there a ground in the toyota harness? If not then that can be a big issue. Some older decks are able to work by grounding through the antenna where as the newer decks cant. If the old deck was grounding through the antenna only and the new one cant that would explain it. On the newer pioneer decks, if you ground through antenna only it will light up but not play audio.
stalt
Member - Posts: 23
Posted: March 10, 2006 at 2:37 PM / IP Logged
YEs there is a ground in the toyota harness
Stalt
geepherder
Posted: March 10, 2006 at 4:59 PM / IP Logged
Sorry, I skimmed through the part where you already had an aftermarket deck before.  I second Kgerry's advice.
