Box building tips?
radiofreak88
Member - Posts: 13
Posted: May 16, 2006 at 9:47 AM / IP Logged
 im kinda new to this and am going to build my second box the first time i had help from a friend and it turned out ok. but i want to build a box for my own now and was wondering if any one could offer me some good tips i cant afford to redo a box im only 17 cash is short for now its a single 8" sub plz help!
rattles suck lets hear your system
AJRXtreme
Silver - Posts: 302
Posted: May 16, 2006 at 10:26 AM / IP Logged
Im 18 and I started building boxes last summer. It's actually a lot of fun doing everything yourself. Well I can tell you what I do. The materials I use are 3/4" MDF wood, caulk, liquid nails heavy duty glue, counter sink drill bit, drill bit a little less than the screw diameter, phillips head bit, drill, dry wall screws 1.5"long and table saw. I first design my box on paper. If you want your box sealed than your going to have an easier time. After you have all your cuts I start with the base and build my way up. I counter sink holes along all 4 edges of the base and then match up pieces, drill a hole about the diameter of the screw through the counter sink and into the board behind it. Then I glue between the pieces and then screw in the screws. Then I add on another piece and before you know it your done. If you have any other questions just PM me.
03 F150 on 24's
HU:Pioneer DVD5700
Frt:MC57
Subs:(12)S12L7
Amps:(3)KX2500.1's, MC-2004
forbidden
Platinum - Posts: 5,354
Posted: May 16, 2006 at 10:41 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=74592&PN=1
