2002 Eclipse
bassplayer24_7
Copper - Posts: 40
Posted: June 16, 2006 at 2:39 PM / IP Logged
i was asked to put a head unit/Amp/Sub in an 2002 eclipse for a friend. my friend went to best buy to get a wiring harness and the installer there said it has a amp under the passenger seat and to put a new head unit in you would have to replace all the wiring in the car.... he also said my friend could go to circut city and they have a special harness/plug but its like 100.00 2002 Eclipse -- posted image.. i was wondering possiblities. thanks in advance
(2) 12" JL W3V3
(1) 6" JL W0
Phoenix Gold Octane R 8.0:1
Phoenix Gold Octane R 2.0:1
Phoenix Gold Octane R 5.0:4
Clarion Crossover
JVC Head Unit
geepherder
Platinum - Posts: 3,668
Posted: June 16, 2006 at 6:43 PM / IP Logged
Basically, he's right.  You can use an amp integration harness, which I'd recommend unless you're replacing all the interior speakers as well.  The factory amp has built in crossovers, so the tweeters have no protection if you hook them up to the deck.  If you're replacing all the speakers, you can either run fresh wire to all locations, or use the wire from the factory amp and "ohm" the speakers.  Read the sticky "how to figure out stereo wiring".  There are other options (doing away with the factory tweets all together,  etc.).
You could always keep the factory deck, and just add the amp and sub.
bassplayer24_7
Copper - Posts: 40
Posted: June 16, 2006 at 6:56 PM / IP Logged
does the factory head unit have rca outputs on it
(2) 12" JL W3V3
(1) 6" JL W0
Clarion Crossover
JVC Head Unit
geepherder
Posted: June 16, 2006 at 7:03 PM / IP Logged
No, but if you're adding an amp/sub, I'd tap the rear speaker wires and connect a line out converter.  You can run your rca's from there.
Insomniacustoms
Member - Posts: 14
Posted: June 16, 2006 at 7:04 PM / IP Logged
no, you are going to have to use a line out converter to change the speaker lever signal to rca level signal. you can just use a 9v battery with soldered on wire leads to pop the speakers to find out which wires are speaker wires to hook the LOC up to them.
bassplayer24_7
Copper - Posts: 40
Posted: June 16, 2006 at 7:05 PM / IP Logged
thanks thats what i figured i'd end up doing. but its always safe to ask if theirs any other possibilities. than ks geepherder
(2) 12" JL W3V3
(1) 6" JL W0
Clarion Crossover
JVC Head Unit
bassplayer24_7
Copper - Posts: 40
Posted: June 16, 2006 at 7:06 PM / IP Logged
thanks, Insomniacustoms
(2) 12" JL W3V3
(1) 6" JL W0
Clarion Crossover
JVC Head Unit
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
