the perfect amp
cutlass013
Copper - Posts: 95
Posted: August 14, 2006 at 9:53 PM / IP Logged
i have 2 pioneer 306c 400w rms and 1000watt max  with a crap amp from like pyramid or sumthing i was wonder if this amp KAC-9102d from kenwood could work with them its mono 850 watt rms at 2 ohm and the subs are single VC 4 ohm could this work is it worth it and does anyone have a kenwood amp   i bought these subs and a "1500" watt 2 channel amp and i think this would sound better is the 50 watts over the rms gonna hurt it..  i am building a fiberglass box for them and will be inverted.. thanks for any info
fosgate152ohm
Member - Posts: 19
Posted: August 14, 2006 at 10:33 PM / IP Logged
Its not the power thatll hurt the subs its the heat and distortion from over powering an amp
cutlass013
Copper - Posts: 95
Posted: August 14, 2006 at 10:38 PM / IP Logged
well would it hurt it that is also at 14 volts and i doubt im getting that.... any other suggestions would be great
aznboi3644
Gold - Posts: 2,600
Posted: August 15, 2006 at 1:03 AM / IP Logged
That amp will do fine.
qnretail
Member - Posts: 32
Posted: August 26, 2006 at 2:43 AM / IP Logged
I have a Kenwood 9102D and you would do fine with your proposed set-up. These are good amps for the price, as long as you are not paying more than $150 for one. Kenwood is CEA compliant so at least you know the power rating has some merit.. as opposed to that Pyramid which is probably rated at whatever output it can do for 1 milisecond at 100% destortion while being struck by lightning..
2 x DD9515f's, Digital Designs Z1 amplifier
KarTuneMan
Platinum - Posts: 7,056
Posted: August 26, 2006 at 3:23 AM / IP Logged
The perfect amp......The Xtant 603X.......
qnretail
Member - Posts: 32
Posted: August 26, 2006 at 3:52 AM / IP Logged
Wait until you hear the new Z class amps from Digital Designs..
Although it really just depends on what you are looking for.
haemphyst
Platinum - Posts: 5,059
Posted: August 26, 2006 at 10:38 AM / IP Logged
Eclipse DA7122. 950 watts at 2 ohms. ICEPowered. CEA. Reliable. Musical. Powerful. Honest. Eclipse.
Crossovers and subsonic filter built in.
Sounds like a perfect amp to me! the perfect amp -- posted image.
russ lund
Copper - Posts: 188
Posted: August 26, 2006 at 11:06 AM / IP Logged
Pyramids and the like have the ILS power rating system.
   IF LIGHTNING STRIKES  !!!
The perfect amp! Ha that doesn't exist but I'm trying to design it.
BigDog
KarTuneMan
Posted: August 26, 2006 at 12:11 PM / IP Logged
The new Zapco digital referance....AND the I-force. The I-force is TRUE bang for buck!!
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
