members only newest auto wiring informati
wiring fool
Member - Posts: 7
Posted: November 19, 2008 at 10:59 PM / IP Logged
how about information between members for the newest autos being released wiring information that can't be found because the vehicles have just been released and the information trail isn't out yet  thanks a million
eieiohztztzt
mikvot
Gold - Posts: 1,043
Posted: November 19, 2008 at 11:34 PM / IP Logged
All you have to do is post a year, make , and model.....you have some of the most knowlegable installers in the US, and the UK ( howie). Heck, we'll even help if you're not a "member"
wiring fool
Member - Posts: 7
Posted: November 19, 2008 at 11:45 PM / IP Logged
2009 f150 no info from remote start company yet maybe in 2 weeks
eieiohztztzt
mikvot
Gold - Posts: 1,043
Posted: November 19, 2008 at 11:59 PM / IP Logged
Sign up for a free account at techservices.audiovox.com
I've a done a remote start, and a couple of alarms on 09 f150s off their info.
Platinum - Posts: 13,726
Posted: November 20, 2008 at 5:01 AM / IP Logged
     Battery          VIOLET/RED          (+)          IGNITION SWITCH
     Ignition 1          WHITE/ ORANGE          (+)          IGNITION SWITCH
     Accessory 1          VIOLET/GREEN          (+)          IGNITION SWITCH
     Starter 1          BLUE/WHITE          (+)          IGNITION SWITCH
     Key Sense          BLUE/GRAY          (+)          IGNITION SWITCH
     Parking Lights          VIOLET/WHITE          (+)          SJB CONNECTOR C2280E PIN 9
     Brake Lights          VIOLET/WHITE          (+)          AT BRAKE SWITCH
     Horn          BLUE/WHITE          (-)          STEERING COULMN HARNESS
Chris Luongo
Platinum - Posts: 3,746
Posted: November 20, 2008 at 6:23 AM / IP Logged
You might also want to joint the Installer Mailing List. Lots of good conversation going back and forth there.
I think if you just google "installer mailing list" you will find it.
Posted: November 20, 2008 at 2:49 PM / IP Logged
Chris, do you still contribute (heavilly) to DEI's forum? I haven't been there in ages.
preussen
Posted: November 28, 2008 at 2:23 AM / IP Logged
I'll add to the listed colors with some other info:
door lock-  grey / YELLOW- (-) polarity- driver's kick or SJB C2280c pin 17
door unlock- violet/grey- (-) polarity - driver's kick or SJB C2280c pin 4
dome light sense- grey/violet - (+) polarity - SJB C2280a pin 9
dome light on - GREEN/ blue - (-) polarity - interior dimmer switch
The listed location for the (+) park light wire as SJB C2280E will work, but I found an easier place was to tie in at the big wire connector, underhood, near the brake booster.  This one is attached to the inner fender, and I found it nice to just run the park light wire with the hood switch wire and make the connection here instead. It is still violet/white at this point. For those who are unfamiliar, the SJB in this truck is in the RH kick panel, which is a pain in the ass. I did find the lock/unlock wires in the LH kick area, but installing a Ford factory remote start with security requires you to run 6 wires over to the RH kick anyway, so I just run the lock wires there with the rest.  Other than going across to the other side, these are cake to install. Hope this helps a bit more.
Slamminsubz
Member - Posts: 12
Posted: January 07, 2009 at 6:16 PM / IP Logged
Im getting conflicting information about the main wires for the 09 F150.
Audiovox is saying to get them at the PSC/ECU MODULE
Boa(DEI) is saying at the SJB
And in this thread is Ignition Harness.
Any idea what the best route is because if i can grab it all at the SJB, ill do all my connections there instead. Thanks.
Slamminsubz
Member - Posts: 12
Posted: January 07, 2009 at 6:19 PM / IP Logged
actually i made a mistake, audiovox says to use the Ignition harness too. So far just DEI says the SJB for all the connections, but it seems strange to grab them from that,
