07 hyundai santa fe python 1400 rs
dsn112
Member - Posts: 10
Posted: January 31, 2009 at 2:48 PM / IP Logged
Hello,
I have done my share of car audio in the past(subs, amps, speakers etc) but never attempted a remote starter with door unlocks.
There are a ton of wires and the installer told me that I won't use half of them.
Questions:
1. Is it fairly simple, and I'm just overwhelmed by the wires?
2. How will I know what I will and will not need to use?
3. Any tips from anyone who has used this model, or worked on this SUV before.
Thanks in advance, I'd like to attempt this tomorrow as it will be warmer out.
Dave
get wired
Member - Posts: 17
Posted: January 31, 2009 at 10:03 PM / IP Logged
1) Yes.
2) You will need all of the heavy guage relay wires (Red, green, purple, pink, pink/wht, and orange). Harness H1 you will need: red, black, and white.  H2: light GREEN/ black.  H3: BLACK/ wht, PURPLE / wht, and brown.  Door locks (green & blue), antenna, and ribbon harness.
3) I usually  connect the blk/wht wire from H3 with ground instead of putting in the switch. Most of your wires will be in the drivers kick panel. Use the negative park lights, it's easier than going to two wires and using diodes.  Make sure you have accurate tech notes for the vehicle from directechs or audiovox. If you don't have a directechs password, Audiovox notes are free. Here's the link:     techservices.audiovox.com  just set up a free account, and you're on your way. Good luck!
Scott Gillis
Owner of Get Wired
Massachusetts
get wired
Member - Posts: 17
H3: PURPLE / wht wire is optional but reccommended
Scott Gillis
Owner of Get Wired
Massachusetts
dsn112
Member - Posts: 10
Posted: February 01, 2009 at 9:16 AM / IP Logged
Awesome info, thanks alot!
dsn112
Member - Posts: 10
Posted: February 01, 2009 at 10:45 AM / IP Logged
Hey all,
where do I wire the hood pin too?
I assume you just tap it in to one of the wires on the python unit, but it doesn't say anywere that I can see which one.
Dave
Posted: February 01, 2009 at 10:57 AM / IP Logged
Blue and diode separate from same wire to trunk.
JWorm
Platinum - Posts: 2,208
Posted: February 01, 2009 at 12:08 PM / IP Logged
Actually, the hood pin input is grey. No diode needed.
Posted: February 01, 2009 at 12:30 PM / IP Logged
Sorry, I was making an assumption wthout checking, my mnd was assuming the original poster had an install manual.
dsn112
Member - Posts: 10
Posted: February 01, 2009 at 4:13 PM / IP Logged
Remote Stater Python xl1400
Hey all, i am almost done my install, i have an issue.
When I go to start, it tries to start for six seconds then stops.
The manual says if you turn the key to on and try and it starts then your ignition wiring is wrong.
Can someone tell me what the wires off of the heavy guage wiring harness should go to.
Im frustrated with this as i have already tried to flip flop my ignition wiring like the manual says.
Purple: Starter side starter wire
Green: Key side starter
Red 12v constant
orange: accessory
Pink white: 2nd igniton
Pink: ignition output
Ive tried a bunch of what i thought to be key side starter wires and all they do is keep the car trying to start the whole time I have it tapped.
Here is what audovox says:
     Battery          RED (40A) & PINK (40A)          (+)          IGNITION SWITCH HARNESS
     Ignition 1          ORANGE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          RED          (+)          IGNITION SWITCH HARNESS
     Accessory 2          YELLOW
     Starter 1          GREEN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          YELLOW          (+)          IGNITION SWITCH HARNESS
Thanks in advance for your expertise!
Dave
get wired
Member - Posts: 17
Posted: February 01, 2009 at 10:42 PM / IP Logged
You most likely need a bypass for your key. Try a DEI 556U.
Scott Gillis
Owner of Get Wired
Massachusetts
