alarm not working properly
rub8322
Member - Posts: 18
Posted: May 28, 2009 at 3:56 PM / IP Logged
hello, i am having problems with my viper 5900 alarm, when i press the lock button on the transmitter .. shows the hood blinking on the transmitter screen after locking all doors and system has been armed. Before i had any problems, if i would disarm the alarm, open any doors and close them again, the led light would start blinking and after 10 to 15 secs the alarm would arm by itself and all doors would lock...now it doesnt do that, when i close all doors the led doesnt blink before the 10 secs to arm itself. any help would be appreciated. thanks in advance
tommy...
Gold - Posts: 1,901
Posted: May 28, 2009 at 8:03 PM / IP Logged
Lets get some more detail...Year,Make,Model...How long has alarm been installed/working properly...? Has the vehicles battery went dead...? On some units all programming goes back to default settings when power is lost...! It sounds like it  might be seeing the hood open...Inspect the hood and see if there is a pinswitch mounted on hood...Inspect wiring at switch...
M.E.C.P & First-Class
t&t tech
Platinum - Posts: 2,622
Posted: May 28, 2009 at 8:10 PM / IP Logged
your hood switch is obviously giving problems, have it checked along with it's wiring.
rub8322
Member - Posts: 18
Posted: May 28, 2009 at 9:11 PM / IP Logged
It is a 93 toyota supra, the alarm has been installed for more than a year now maybe two, it was working fine before i replaced the alternator fuse, there is a pin switch mounted on the hood.
rub8322
Member - Posts: 18
Posted: May 28, 2009 at 9:14 PM / IP Logged
is there a way to have the brain reset. ive tried while having a door opened and the key in the ignition, then hold the deactivation button that is hidden for a while after the second press, but it doesnt do anything.
rub8322
Member - Posts: 18
Posted: May 31, 2009 at 1:17 PM / IP Logged
i checked the pin switch and its wire and they are both ok. i checked the brain and all wires seemed to be ok and in place.
tommy...
Gold - Posts: 1,901
Posted: May 31, 2009 at 5:58 PM / IP Logged
Lets dis-connect the hood pin wire and see what happens...Why did the alternator fuse blow...?
tommy...
Gold - Posts: 1,901
Posted: May 31, 2009 at 6:01 PM / IP Logged
Im guessing it is not auto-arming ...The feature where you shut your door and the alarm automatically arms and locks doors...Probably like T&T said...There is most likely a problem w/ your hood pin/wire...Do you have a DMM...?
rub8322
Member - Posts: 18
Posted: June 01, 2009 at 12:49 AM / IP Logged
[QUOTE=tommy...] Lets dis-connect the hood pin wire and see what happens...Why did the alternator fuse blow...?[/QUOTE
how do i disconnect the hood pin wire in a safe way, also the alternator fuse blew because a friend and i were washing the car from underneath and i guess the fuse blew because the alternator got wet and then the car wouldnt start, so we had to replace it.
rub8322
Member - Posts: 18
Posted: June 01, 2009 at 12:52 AM / IP Logged
it is exactly what you are saying tommy, the alarm is not auto-arming, plus it shows the hood icon when i arm it my self so i guess it is related on a same problem causing both things to happen. what is a DMM, sorry im a noob with this things :)
