2004 f150 supercrew 5.4
kenora
Posted: August 20, 2009 at 12:09 PM / IP Logged
hi, just bought this truck.  while driving the dash lights flash, hear clicking noise and then truck makes whistling noise. truck has keyless entry. any ideas.  i use remote to lock and unlock the door.
kenora
mikvot
Gold - Posts: 1,043
Posted: August 20, 2009 at 2:47 PM / IP Logged
Is it a factory, or aftermarket keyless entry?
09f150
Member - Posts: 14
Posted: August 20, 2009 at 4:15 PM / IP Logged
almost sounds like the alternator is going bad.  I'd have the charging system checked out asap.
09f150
Member - Posts: 14
Posted: August 20, 2009 at 8:15 PM / IP Logged
I should note that before I had my 09, I used to have an 04 F150 with the 5.4 too.  They were known for having bad alternators that first year although I never had any problems with mine.  When all the lights and stuff start going crazy while driving, that is usually a sign of a bad alternator.  Let us know what you find out if you get the charging system checked.
kenora
Posted: August 21, 2009 at 2:00 PM / IP Logged
thanks guys for the quick response. will heed your advice and have the alternator checked asap.
thanks again,kenora
kenora
