pats 2
mike swanson
Copper - Posts: 290
Posted: August 25, 2009 at 5:20 PM / IP Logged
I have a 99 chevy cavalier that the ign has been changed out and the computer has not been relearned to the new ign.
any way around this?
I dont have the old key or ign.
I think this is a bulb test car and i would just have to guess the resistor value.
Chris Luongo
Platinum - Posts: 3,746
Posted: August 25, 2009 at 11:05 PM / IP Logged
PATS is a Ford system. Your car has either Passlock I or Passlock II.
Anyway, go here:
https://www.the12volt.com/installbay/forum_posts.asp?tid=72296&KW=permanent+passlock+bypass
Go to the fifth post down, and then go to the part that says "5. PROGRAMMING."
Since you don't think your car has a defective Passlock sensor in the ignition switch, just ignore all the stuff about the resistor and the cutting and splicing......just go with the programming first and see if it works.
mike swanson
Copper - Posts: 290
Posted: August 26, 2009 at 9:04 AM / IP Logged
yes thank you it is passlock 1. I mutitask to much and this is the result. I type Not what im thinking, but still thanks
the security light just stays on, No blinking
Also i think this car has the bulb test where the black wire from the main ign wires needs to be hooked up
with the sec lite NOT blinking. I think the bcm is bad?
,But yes this is VATS PASSLOCK 1
