2006 gmc sierra keyless entry
salden77
Member - Posts: 11
Posted: November 19, 2009 at 5:51 AM / IP Logged
2006 gmc sierra W/T came with power locks, no factory keyless entry, need to know what bypass to use if any. and also wiring diagram.
salden77
salden77
Member - Posts: 11
Posted: November 19, 2009 at 6:05 AM / IP Logged
installing aftermarket key less entry/alarm.
salden77
Mike M2
Platinum - Posts: 2,652
Posted: November 19, 2009 at 6:21 AM / IP Logged
Look above for the link "vehicle wiring" and look under 2006 Chevy Silverado, it's the same. No bypass for just  keyless/alarm, lock wires are at the BCM.
Mike M2
Tech Manager
CS Dealer Services
Platinum - Posts: 12,488
Posted: November 19, 2009 at 7:33 AM / IP Logged
Mike, the locks wires are no longer at the BCM for these truck ( since 2002 ). The lock wires are data and he will need to use a iDatalink ADS-DL to control the OEM alarm as well as the lock and unlock.
kgerry
Platinum - Posts: 3,455
Posted: November 19, 2009 at 2:35 PM / IP Logged
if you are doing alarm/keyless only, not R/S you can also use a MULTIDL or 456G or equivalent as you don't need to bypass the PL circuit.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Mike M2
Posted: November 19, 2009 at 3:55 PM / IP Logged
Jeff, i have to disagree. The WT trucks are 2 door and have no DDM, thus the lock pulses should be in the drivers fuse box or the BCM. This is true even on the 2007 and up WT's. No module is needed to control locks on any WT since they were thought of....
Mike M2
Tech Manager
CS Dealer Services
salden77
Member - Posts: 11
Posted: November 19, 2009 at 6:18 PM / IP Logged
i checked the lt. blue plug at the BCM, no wires for the door locks on pin b5, or pin b10
salden77
Mike M2
Posted: November 19, 2009 at 6:51 PM / IP Logged
Huh, are you sure this is a WT? How many doors does it have?
Mike M2
Tech Manager
CS Dealer Services
robertsc
Copper - Posts: 337
Posted: November 19, 2009 at 7:53 PM / IP Logged
I did a 2009 sierra today doorlock wires were at the bcm pink plug
truck did not have a factory alarm
Platinum - Posts: 13,726
Posted: November 19, 2009 at 7:59 PM / IP Logged
I have seen several posts here about the Work Trucks being different from the more commonly seen upper end trucks.  The work trucks do have conventional door lock systems.
Page of 3
