1997 honda del sol, option group alarm
zolton
Posted: April 11, 2010 at 1:39 AM / IP Logged
Greetings:
Installation instructions are vague about the procedure for connecting the door locks. Are relays necessary or can i just connect the unit directly to the lock wires? (500ma)
t&t tech
Platinum - Posts: 2,622
Posted: April 11, 2010 at 6:20 AM / IP Logged
If you have negative trigger it's direct connection to the trigger wires! You have to verify locking type first!
Posted: April 11, 2010 at 8:12 AM / IP Logged
Just be careful, some Hondas up that vintage usually Japanese built required a motor in driver's door. What is an "option group alarm?"
zolton
Posted: April 11, 2010 at 11:00 AM / IP Logged
Thnaks for your replys.
How do you verify the locking type?
Option group alarms are widely available on ebay for about 35 bucks. currently there are 62 offered. they all look to be the same.
cheers
t&t tech
Posted: April 11, 2010 at 12:17 PM / IP Logged
 DON'T buy alarms that you've never heard off from e-bay! (You might get shot1997 honda del sol, option group alarm -- posted image.), ted knows what i'm saying,LOL,
If you don't have a diagram for the vehicle then do you have a meter, this is the way we will decipher locking type, although i would go out on a limb and say negative trigger, we still have to check!
darksidecelica
Member - Posts: 30
Posted: April 11, 2010 at 2:38 PM / IP Logged
the hondas are usually a negative triggered locking system. Again verify with a DMM to be sure.
tedmond
Gold - Posts: 4,610
Posted: April 11, 2010 at 4:59 PM / IP Logged
lol t&t, yes i do.
i wouldnt buy or install an ebay unit. i have before and never will i do it again. they are a PITA to diagnose when things go wrong.
on that note, never heard of that brand ever, and the locking system is type B aka negative trigger.
Ted
Compustar Expert
t&t tech
Posted: April 11, 2010 at 6:05 PM / IP Logged
Then yes to the OP, the interface is direct!
Posted: April 12, 2010 at 4:03 AM / IP Logged
Except the piece of junk probably won't work, what do you expect for £22? Might as well throw the money away. Don't buy anything electrical off of fleabay, even known brands. Couple of years ago a regular customer bought an Alpine Sat Nav that way, everything worked fine except the DVD sat Nav, luckily I knew people at Alpine and got it repaired under goodwill warrantee, the so called "dealer" wasn't and Alpine wanted to have a "chat" with him!
Why do we even bother with posters who've been fleabayed?
Why do you think the equivalent from a "proper" brand such as DEI Avox/Code etc. costs 5-10 times as much?
