domelight
Malibu2882
Member - Posts: 13
Posted: April 21, 2003 at 2:54 AM / IP Logged
I need help. I had a GM factory alarm installed but Domelight suppervision was an option(needs relay) Well I wired up the relay and tapped the wires.But the domelight will not come on when the alarm is disarmed. I can hear the relay time out after I disarm (30sec). I have negitive door switches. I wired it up just like the guide said. 87-negative 85 12v fused 30 negitive door trigger, 86 alarm oillumated output, 87a none. I used the wires coming out of the main unit, could this be it? I don't know what I'm doing wrong. Please help! Thanks!
Dave
draasch
Gold - Posts: 2,172
Posted: April 21, 2003 at 5:16 AM / IP Logged
is pin 86 a neg output??
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Malibu2882
Member - Posts: 13
Posted: April 22, 2003 at 1:33 AM / IP Logged
Yes, pin 86 is neg. 200mA illumated output
Dave
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
