viper 211 keyless entry
fatmax
Member - Posts: 6
Posted: March 01, 2011 at 8:49 PM / IP Logged
I have a 79 F-150 that I have re-wired using the EZ Wiring kit.  I added door actuators to the doors.  They have two wires each.  Now I would like to add door lock switches and the viper 211 keyless entry.  The problem is that I do not no how to wire the viper system or the switches.  I am planning on using aftermarket switches from SPAL.  Below is the wires with the Viper 211 system.  I have a door lock power wire coming from the fuse box and I figured it wires to the H1/1-red wire .  From here I'm lost.   I do not care about the horn honk but I would like to use the domelight supervision and the parking light flash wires. .  Please help.
H1/1-Red    (+) 12V constant power input
H1/2-Blue   (-)200ma Second unlock output
H1/3-BLACK/ White-1      Input of domelight supervision relay #87
H1/4-BLACK/ White          Output of domelight supervision relay #30
H1/5-GREEN/ Black         lock #30 Common output
H1/6-WHITE/ Black            lock #87 Normally closed
H1/7-Violet/Black            lock #87 Normally open (input)
H1/8-Blue/Black              unlock #87 normally open (input)
H1/9-Violet                        unlock #87 normally open (input)
H1/10-White                     (+-/-) Parking light flash output
H1/11-Black                      (-) Chassis Ground
H1/12-Brown                     (-) Horn honk output
H1/13-Lt. GREEN/ Black     factory alarm disarm
H1/14-WHITE/ Blue              (-)200mA channel 3 validity output
H1/15-Yellow                     (+)switched ignition
H1/16-Orange                   (-)500mA ground when armed output
H1/17-BROWN / Black           unlock #87a normally closed
H1/18-RED / White              (-)output of channel2
Posted: March 02, 2011 at 12:29 AM / IP Logged
Get the switch, you only really need one by the driver but it is doable with four. You will be carrying 3 wires to each door, one a constant live fused at 7.5 amps per motor;
GREEN/ black and blue/black to each door actuator (motor).
Purple and PURPLE / black to 30amp fused constant.
BROWN / black and WHITE/ black to ground.
Or dispense with the switches completely which is the normal way of doing things and simply programme the unit for ignition lock and unlock.
Also with 4 switches you will only be operating one door with each switch. The whole thing becomes extremely complicated.
Mike M2
Platinum - Posts: 2,652
Posted: March 02, 2011 at 6:40 AM / IP Logged
I agree, using Howies info will make the locks work fine off the keyless, but adding the switches means they will need thier own relays. The easiest way would be to buy a 451M relay from DEI, it will have the exact same wiring as the above info from Howie. Use this relay to control the switches alone...
Mike M2
Tech Manager
CS Dealer Services
Posted: March 02, 2011 at 8:01 AM / IP Logged
Apart from the fact that :
A) If this unit has (ign) auto-lock and unlock, there's no need for a switch.
B) Otherwise you would need to parallel that output to 4 master and 4 slave switches wired via 5 contact switches (DPCO) as electric window switches, stupid kludge.
fatmax
Member - Posts: 6
Posted: March 02, 2011 at 7:34 PM / IP Logged
I have two doors and would like a switch on each door, driver and passenger side.  O.K. so I wire the H1/1-red wire to the door lock power wire coming from the fuse panel.  Then the H1/11, H1/17, & H1/6 all just ground to the cab with a screw.  Then wire theH1/5 & H1/8 to the door actuators.  I lost on where to wire the H1/7 & H1/9.  Would they wire to the door lock power wire coming from the fuse box also? What about the H1/15 yellow ingnition wire and the H1/2 bluue wire that unlocks the passenger side when you push the unlock button twice on the key pad?  The SPAL switches (part # 37000118) have a wiring harness but I would still have wire in the keyless.  As you can tell I'm completely lost.  Please help.
brcidd
Copper - Posts: 274
Posted: March 02, 2011 at 8:22 PM / IP Logged
Why did you not choose the five wire actuators that come in the aftermarket doorlock kits?  They have no need for switches, in that when you physically move the manual lock, (or use key in door lock) the actuator moves and automatically unlocks (or locks) the other doors.  The switch is built into the actuator- on either front door.  They work great.
Perhaps you only bought actuators, but a aftermarket kit would have given you the relays built into the controller and the two (-) negative input wires to be driven by a remote starter, or keyless entry module....
My first door lock actuator install, I did the same thing- actually went to a boneyard and bought switches out of a given vehicle-- then when I got the kit, I soon realized, no switches necessary...I wasted a lot of time and planning, not realizing how easy it could actually was..
Brcidd - Engineer That Does Remote Starter Installs on the side.
fatmax
Member - Posts: 6
Posted: March 02, 2011 at 8:33 PM / IP Logged
I did not want the central locking system.  I personally would rather have the switches.  When I bought the viper keyless system The salsman said that switches could be wired in.
fatmax
Member - Posts: 6
Posted: March 03, 2011 at 5:29 PM / IP Logged
Can anyone help me.
t&t tech
Platinum - Posts: 2,622
Posted: March 03, 2011 at 8:06 PM / IP Logged
Wild thought just popped into my head, it could be totally stupid depending on how u look at it, purchase two spdt switches, wire the lock for a 12 at rest system, and pick up the ground in the doors and wire in the switches at each door, no extra relays needed, it still does get complicated though.
fatmax
Member - Posts: 6
Posted: March 03, 2011 at 8:41 PM / IP Logged
I do not know what spdt switches are or a 12 at rest system.  I am going to need like this color wire goes here, etc.  I was under the understanding that all the relays needed where built into the sytem and all I would have to do is run the wires to the right place and make the connections.
