2003 dodge ram with viper 5101
stsymbal
Posted: February 18, 2012 at 4:46 PM / IP Logged
I was wondering if anyone could give some guidance on how to install a Viper 5101.
Recently i had purchased a Viper 5101 online for my 2003 Dodge Ram 1500 regular cab.
The problem is it has no instructions. I did locate some info on here but the info is vague.
Such as door locks .I did get them to work but it took a couple of different diagrams and resistors. Couldn't get the headlights to work
Pretty much what I am getting at is could someone give me color to color info with diagrams.
I had never installed 1 before so I could use a little help
Platinum - Posts: 7,828
Posted: February 18, 2012 at 6:21 PM / IP Logged
Not one of the easiest vehicles to do for a novice.  Here is a link to Bulldog Security :
  http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
They have the wiring guide, special relay circuit diagrams and color pictures to assist you in the install.
Here is a link to the Viper 5101 Install Guide.  All Viper products are intended for professional
installation and this guide was written for them.    https://www.the12volt.com/installbay/file.asp?ID=830
You will need extra 30/40 Amp SPDT relays, resistors and possibly a transponder bypass module ( if
you have a Gray ignition key ).  A Digital Multi Meter and soldering gun will also come in very handy.
opelap
Member - Posts: 40
Posted: February 21, 2012 at 11:45 PM / IP Logged
Or go the more expensive but easier route and get a EVO-ALL with the Dodge harness, or the DEI CHALL and all of that resistor junk is taken care of.
stsymbal
Posted: February 22, 2012 at 7:23 PM / IP Logged
Well I already have the unit...Worked on it a little have the door locks working thanks to kreg357..
Will work on it some more probably this week if schedule allows.
