info needed, door trigger
starplayerzz
Member - Posts: 14
Posted: March 28, 2012 at 12:46 AM / IP Logged
my door trigger is wired to the negative output of my alarm. the sirem trips off when the door is closed and not when it is open. does that mean i need to wire it to the positive door trigger output form the alarm
chev104275
Gold - Posts: 1,436
Posted: March 28, 2012 at 5:34 AM / IP Logged
Did you test the trigger wire before hooking into it ? If not testing will answer that question for you
starplayerzz
Member - Posts: 14
Posted: March 28, 2012 at 7:40 AM / IP Logged
no i didnt test it im gonna test it now
starplayerzz
Member - Posts: 14
Posted: March 29, 2012 at 12:45 AM / IP Logged
okay i tested it its a negative trigger i hooked it up to the negative trigger input on my alarm but the siren still trips off when i close my door.
chev104275
Gold - Posts: 1,436
Posted: March 29, 2012 at 6:59 AM / IP Logged
What kind of car are we working on ?
starplayerzz
Member - Posts: 14
Posted: March 29, 2012 at 8:00 AM / IP Logged
mazda 626 dont really know the exact year. the alarm is a prestige APS 25C
racerjames76
Silver - Posts: 581
Posted: March 29, 2012 at 8:52 AM / IP Logged
The door triggers are likely open, not negative. Meaning they rest at ground (explaining your false trigger with the door closed). If you tested properly with a volt meter you would have seen this, even if you hadnt read the notes in the wiring diagrams. Someone will post the diagram shortly I am sure.
chev104275
Gold - Posts: 1,436
Posted: March 29, 2012 at 9:01 AM / IP Logged
All my sheets says its a RED / white at the fuse box    what are you using ?
starplayerzz
Member - Posts: 14
Posted: March 30, 2012 at 9:32 AM / IP Logged
i am using that sane wire
chev104275
Gold - Posts: 1,436
Posted: March 30, 2012 at 12:13 PM / IP Logged
How did you test it ? where were your leads ?
Saturday, November 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
