viper 5701
hybridamp
Member - Posts: 29
Posted: July 30, 2012 at 10:25 AM / IP Logged
I've installed several 5900's, with the satellite relay pack, into my previous vehicles with no problems at all.  Actually, I found the install manual to be easy and straight forward.
As for the 5701, the on-board flex relay wiring has me a little confused.
I have a simple configuration: 1 Ignition, 1 Starter, and 1 Accessory, so what heavy gauge wires connect to which circuits?
Here is what I believe I have figured out:
Starter
Input - ?
Key side - Green
Car side - Violet
Ignition
Input - ?
Output - Pink
Accessory
Input - ?
Output - Orange
Platinum - Posts: 7,827
Posted: July 30, 2012 at 11:56 AM / IP Logged
Starter
Input - ?    H3/9
Key side - Green
Car side - Violet
Ignition
Input - ?   H3/6
Output - Pink
Accessory
Input - ?   H3/9
Output - Orange
H3/2 is power input for flex relay, with H3/7 as output.
hybridamp
Member - Posts: 29
Posted: July 30, 2012 at 12:01 PM / IP Logged
Thanks!  Already started soldering the low voltage connections, how shops can do these installs in a few hours I have no idea; I guess it comes with experience.
hybridamp
Member - Posts: 29
Posted: July 30, 2012 at 12:03 PM / IP Logged
low current I mean't;  heat is getting to me, very much need an insulated garage.
smokeman1
Platinum - Posts: 1,589
Posted: July 30, 2012 at 12:44 PM / IP Logged
Connect the RED / White, Red, and RED / Black from the heavy gauge harness to the vehicles constant 12 volt source.
hybridamp
Member - Posts: 29
Posted: July 30, 2012 at 8:19 PM / IP Logged
Ok, and I got the outputs correct also in regards to colors?  Thanks for your help by the way, couldn't figure why the first reply had the same input wire.
I got all my low current wires soldered today except for the tech because I'm going to have to pull my instrument cluster.  A few wire colors were reversed from the info I found here (must just be my specific model) which took me a while to figure out.
smokeman1
Posted: July 30, 2012 at 9:01 PM / IP Logged
What year make and model Vehicle are you working on?
hybridamp
Member - Posts: 29
Posted: July 31, 2012 at 8:14 AM / IP Logged
03 Nissan Frontier XE-V6, factory keyless entry with no factory alarm.
1st and 2nd Starter were combined in the harness for some reason, makes it easier for me I suppose.
My door triggers (w/ factory dome light delay) were green w/red (drivers door) and red w/black (other 3 doors) instead of what was listed on the color code sheet; diode isolated of course.
My smart entry module wasn't where listed either, instead it was to the right of the steering column directly before the ECM; not above the hood cable in the driver's kick panel as listed.  Tested a ton of wires in that location first before hitting the keyless entry and listening for the relays clicking.  I guess I should have checked a second source of info first as bulldog had its location listed correctly.
hybridamp
Member - Posts: 29
Posted: July 31, 2012 at 10:35 AM / IP Logged
Don't think the tach wire color code is right neither now that I have the instrument cluster out; what is the method for testing tach with multimeter?
Posted: July 31, 2012 at 11:45 AM / IP Logged
Don't worry some vehicles take data from the engine management to the inst. panel to provide tach and other functions.
Engine management if you can find a list of pin-outs.
Or injectors or coil packs.
On the injectors you will have two wires going to each injector. One wire has a common colour to each, use any of the other uncommon.
To confirm take a DMM, set to 20VAC and place black probe to ground, red to the suspect wire.
With the engine running you should get a reading of 3-5VAC, increasing slightly as you raise the revs.
As a side issue, inst. panel out might give you enough space to mount the brain behind and bring t5he cables down to the different locations, a nice, safe stealthy install.
Friday, October 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
