cm6000 firware update
Lubrano
Copper - Posts: 113
Posted: December 31, 2012 at 1:29 PM / IP Logged
I need to update the firemware on a cm6000 to gain some features which will be used.  I do not own an op500.  Is there any way I can do this rather inexpensilvely, maybe buying a cable to go directly to a pc?
shortcircuit161
Silver - Posts: 556
Posted: December 31, 2012 at 2:50 PM / IP Logged
You might be able to update and change features on the idatalink website. That would require the use of their programming cable (ADS-USB) and a dealer account (or know someone who does). I know a lot of the newer model Compustars (6200's) can be updated and modified right from their site. Otherwise, you would need the OP-500.
lucasoil4u
Copper - Posts: 317
Posted: January 16, 2013 at 3:11 PM / IP Logged
You can update that way but you will need to insert a blade module to do that.
